by jesawdy on Sun Dec 17, 2006 11:55 pm
Well, if it won't lead to a divorce, I would recommend that you consider a machine that can be plumbed. It makes it very, very convenient, and you'll probably find yourself using that machine a bit more because it is so convenient. It takes less time to setup (no need to check water levels) and less time to use and to clean, just flush into the plumbed drip tray as much as you wish.
Yeah, I know it seems crazy, but you might consider yourself lucky that you don't have to go through an upgrade cycle. Plumbed machines at the $1500 or less would be that Bezzera (with plumb options), La Valentina, Andreja, Vetrano, Fiorenzato Bricolleta, Izzo Alex, and for a bit more money La Spaziale Vivaldi. You'll also have a less frustrating, consistent and forgiving machine in this price range (as you should). The Izzo Alex seems particularly attractive with the pourover, plumb-in options considering you will be moving in the near future, if you could not plumb it now.
As for a used machine, that is a call you have to make for yourself.... it depends on how handy you are, and whether your willing to be out there on your own without any warranty or direct vendor support.
Good luck!
Jeff Sawdy
