Paul_Pratt wrote:To turn [electronic preinfusion] ON - turn power switch to off and then hold the first button on the left keypad. Turn power to ON (Fill position if you have it). Then the led above the continuous will come on. I think this will lock up the buttons so you may have to turn on/off again.
To turn [electronic preinfusion] OFF - repeat above but its the 2nd button (not the 1st) on the left keypad. Again led should come on etc..
Works exactly as Paul says it should. The controls do lock up after turning the electronic preinfusion on or off, so you need to cycle power. Oddly, electronic preinfusion is only available on the green or single buttons, and not on the red or double buttons.
No bother really for a "home-barista", but I do wonder why preinfusion is not available on the double buttons? Is it because the single puck is more "delicate" and preinfusion is needed more for a single? Are La Marzocco's with this feature the same?
Now if I only had Chronos, that's a feature I really would like to have (more so than dosing)! Paul or anyone, can Chronos like functionality be hacked onto one of these control units? Some sort of timer that runs when a shot is running.
