Geoff
HB wrote:If the auto-fill engages while pulling a shot on a vibe pump, the brew pressure will drop precipitously.
Even if the shot pressure didn't dive if auto-fill kicked in during the pull the shot would be ruined anyway since shot temp would likely dive!Ken Fox wrote:Are you sure of this, Dan? I have never owned a vibe pump machine with autofill, but I think this would depend on where the OPV is located, assuming one has one and has adjusted the OPV in the machine. If the vibe pump would get up to 14 or 15bar in its unmodified state, and especially if the OPV is located distal to the input solenoid, I think it is very possible that the pressure at the puck would remain unchanged as the pump is capable of producing almost twice as much pressure at the group as one has the OPV set up to deliver. I think this all is going to depend on things such as how the plumbing is designed and configured in a given machine. Testing this would be very easy as all it would require is a PF Manometer; one could start a shot then immediately drain enough water out of the water wand to get the autofill to kick on, then look at how the PF manometer reading changes.
ken
miKe mcKoffee wrote:Even if the shot pressure didn't dive if auto-fill kicked in during the pull the shot would be ruined anyway since shot temp would likely dive!
That would certainly be true with a mammoth boiler like on your Juniors!Ken Fox wrote:That would depend on when the autofill kicked in during the shot, the machine involved, and whether the shot being made was one in a series or if it was being made alone, with no shot immediately following. The autofill kicking in during the shot is more likely to effect the temperature of the NEXT shot than it is to effect the shot in question.
ken
Ken Fox wrote:If the vibe pump would get up to 14 or 15bar in its unmodified state, and especially if the OPV is located distal to the input solenoid, I think it is very possible that the pressure at the puck would remain unchanged as the pump is capable of producing almost twice as much pressure at the group as one has the OPV set up to deliver.
HB wrote:The 14 or 15bar you refer to is a zero flow. The max pressure a vibe pump can produce drops off dramatically with an increase in flow rate... When the boiler refill solenoid opens, the water will flow into the boiler in a hurry as it's offering only ~1 bar of resistance, compared to the puck / OPV's ~9 bar.
Ken Fox wrote:Rather than speculating on this I think it would make more sense to test it, being as it is very amenable to testing and requires equipment that many have. I will attempt to test some of this on my plumbed in rotary machine, realizing that the results aren't necessarily applicable to a vibe machine with autofill.
There are two things to test: (1) effect of autofill on brew temp during the initial and maybe 1 or 2 subsequent shots made at reasonable shotmaking intervals for a particular machine, say one shot per 1.5 or 1 shot per 2 minuts; (2) effect of shot pressure measured by PF manometer before and during autofill engagement.
The equipment needed to accurately observe this would include a Scace Device (preferably) plus datalogger for #1, and a PF manometer for #2. I don't think that a front panel pressure gauge would necessarily be as accurate for this measurement but I could be wrong.
ken
LeoZ wrote:why not the flow as i watch it come out of my grouphead? it slows down enough to be seen...
