Getting started with the Vibiemme DoubleDomo Super - Page 4
Link to "Getting started with the Vibiemme DoubleDomo Super"by HB on Thu Apr 17, 2008 8:53 pm
stefano65 wrote:the traditional looking one they have a 1.8 calibration...
Some of the espresso machines I've tested included the factory inspection sticker showing it passed pressurization. They're not as high as you might think - only 2.0 bar, if I remember correctly. Personally I would sleep better knowing it's idling well below the factory pressure test:
Link to "Getting started with the Vibiemme DoubleDomo Super"by cannonfodder on Fri Apr 18, 2008 12:26 am
Boiler level probes. These probes tend to be pretty generic, just a steel rod with an angle at the top for the level box connection. They are usually cut to length for the boiler. I would not worry that the probe is completely inserted into the boiler since it was probably trimmed to a specific length for that boiler. With all the steam talk, I was thinking about playing with the water level as a possible fix. More water = higher pressure but less volume, lower level get you more volume but with less pressure. The key is matching the volume, heating element and steam tip to provide sustained steam.
cannonfodder
Link to "Getting started with the Vibiemme DoubleDomo Super"by CafSuperCharged on Fri Apr 18, 2008 2:00 am
Dave, I'd point to Ian's analysis:
cafeIKE wrote:Steam production and foaming milk successfully rely on several interelated factors.
It's the velocity of the steam that produces the foam.
The velocity of the foam is related to the hole diameter, steam volume and pressure.
More water, i.e. higher level will produce more steam when the pressure is released. The potential volume of steam is directly related to the water volume and temperature above the local boiling point at the boiler pressure. The down side of a high water level is the initial volume of steam is reduced and the pressure drops more rapidly when the valve is opened, reducing velocity.
The capacity to continually produce steam is related to the heat input, the input water temperature and the pstat setting. The water level has no effect. Water level affects how quickly the system can recover once the valve is closed.
The water level probe can be adjusted by loosening the small upper nut slightly and pulling up on the probe.
cannonfodder wrote:[...]With all the steam talk, I was thinking about playing with the water level as a possible fix. More water = higher pressure but less volume, lower level get you more volume but with less pressure.
More volume = higher pressure? The discussion reminded me of some of the saturation physics. The equation would not be true, I think, but am not 100.000% sure the water/steam are in saturated condition as per physics definitions.
I would say, more water creates more heat inertia so you suffer less from incoming cold water and the effect of losing steam maybe even. Losing steam however has serious cooling effect and must be compensated by switching on the steam heater a.s.a.p. In this sense, pressurestat deadband may be part of the equation.
Less water would mean more (saturated) water damp, at least initially.
cannonfodder wrote:[...]The key is matching the volume, heating element and steam tip to provide sustained steam.
From Ian's analysis I became aware of another aspect of the steam tip. Personally I never steam, so I have to discover these things, reading around. Most discussions I read on steam tips seem to focus on nr, size and angle of the holes. In fact, most of that discussion is an optimization problem that will differ per machine and where the discussion implicitly is about (flow) speed of the steam. The question then is if less holes or smaller holes in the steam tip could still maintain flow/speed of the steam, even when passing less quantity and what the effect would be on the time needed to heat the same amount of milk.
As to the VBM DB, part of the "not enough steam" discussion should then focus on nr of holes and diameter.
Having seen the photos and this debate, I would want to insulate that steam boiler btw. Being small, its surface area relative to its contents is larger than would be the case with a larger boiler. If it really would extend the steam life of the boiler is still to be seen though.
HB wrote:Some of the espresso machines I've tested included the factory inspection sticker showing it passed pressurization. They're not as high as you might think - only 2.0 bar, if I remember correctly. Personally I would sleep better knowing it's idling well below the factory pressure test: [youtube movie]
I am sure the leading people in these fora are aware of this and most certainly Dan/HB, but what you see in the movie is supposed not to happen with your espresso boiler because it has an over-pressure valve (OPV). The experiment in the movie requires the OPV to either be sealed (made dysfunctional) or replaced by a permanent cap. It seems to me the boiler was prepared for the experiment as you can see one of the end plates has nicely come off for it to behave like a steam driven rocket.
In your espresso machine, if the OPV is opened, I wonder if it would close again when the pressure drops. I would expect it needs replacement, in which case you need to stay away from the maximum pressure it was designed to open at.
Regards
Peter
Netherlands
Europe
CafSuperCharged
Link to "Getting started with the Vibiemme DoubleDomo Super"by cannonfodder on Fri Apr 18, 2008 9:31 am
CafSuperCharged wrote:Dave, I'd point to Ian's analysis:
I believe that is what I said. More water gives you more pressure but less volume of steam so it goes flat fast. Less water gives you more steam but at a lower velocity.
CafSuperCharged wrote:In your espresso machine, if the OPV is opened, I wonder if it would close again when the pressure drops. I would expect it needs replacement, in which case you need to stay away from the maximum pressure it was designed to open at.
Yes, they will reset. The valves are spring loaded, think OPV on steroids. When the pressure gets above a point, the piston compresses the spring and opens the release valve, venting the excess pressure. When the pressure drops back down the spring/piston closes, unless it is caked with scale then it may stick.
Edit, a clarification. When I say on steroids, I am referring to the physical size. The boiler valve tends to be physically larger than the OPV, although VBM uses a larger than average OPV. The OPV opens at a higher pressure than the boiler pressure release valve, but they have the same base principal. A spring loaded valve that opens at a given pressure.
cannonfodder
Link to "Getting started with the Vibiemme DoubleDomo Super"by buzzmc on Tue Apr 22, 2008 10:51 pm
I'm having a heck of a time with my new DoubleDomo.
Bottom line, very light colored Crema from a coffee that I know when brewed properly produces medium->dark crema.
I think I need a scale to dose out 14g and see what that looks like from the way I dose now, but my dosing method worked on my Adreja Premium.. I suppose that doesn't really matter with the new Machine.
Maybe some VBM Super owners know if the VBM is really sensitive to dose... I think this is part of my problem... And I'm sure pictures would help, but I'm picture-defunct right now.
After brewing you can clearly see the brewhead screen imprint on the puck. This leads me to believe I'm overdosing, likely to a detrimental extent, and then all other bets are off. I've visually dramatically reduced my dose, to the point where before distribution/tamp coffee doesn't even come to the top of the portafilter (the mound in the middle is higher, but not by much, which makes it difficult to get 'even' distribution). Even at this "low" a dose I see the screen imprint on the freshly brewed puck, loud and clear.
I have the PID set to 107 right now, and I believe my display is in Celcius as it only goes to 130. I'm assuming a 205f brewtemp is about right, and I'm trying to error on the side of darker anyway, thus the 107... But crema is very, very blonde, even with a shot cut short at 23sec, and even on my over-tamped 12bar 40second or so shot.
"Slightly frustrated" ;)
buzzmc
Link to "Getting started with the Vibiemme DoubleDomo Super"by cannonfodder on Wed Apr 23, 2008 9:37 am
What kind of beans are you using, how old are they. I am assuming they are not old subpar beans. Light Crema could be channeling or low brew temperature, provided it is not the beans. If you are overdosing too much and the puck is scraping the shower screen when you lock it in you may be causing cracks in the puck and channeling. I am assuming the DoubleDomo and the Domabar Super use the same group, 14-15 grams should not be a problem. If you are getting a shower screen imprint before the shot (tamp, lock in and then remove it) then you are putting in way more than 14 grams, probably more like 18-20. If you have a light imprint on the puck after the shot but not before, that is OK. The puck swells during the shot and will often lightly touch the shower screen.
If you don't have a scale, and it does not sound like you do, you may want to start there just to confirm your dose. You will need one that has one tenth accuracy. A one gram scale won't do much good since it can be off by half a gram or more.
Someone correct me if I am wrong, but 107 Celsius is 224.6 Fahrenheit, a little hot for espresso. I believe I read that there was a 7-10 degree drop between the boiler and brew group. Split the difference, say 208 in boiler for 200 at the group, you would need a PID setting of 97.7 Celsius. You may want to try turning down the PID a bit.
cannonfodder
Link to "Getting started with the Vibiemme DoubleDomo Super"by buzzmc on Wed Apr 23, 2008 12:05 pm
Beans from barefoot, roasted on 4/18... And a bean I've used a lot and like... Quite doubtful it's the bean.
Temp: My converted says 205F=96.1C. I just doublechecked with this site: http://www.wbuf.noaa.gov/tempfc.htm and it says the same. So I added 10, and then +1'd it because I was trying to get darker crema, nothing more.
I'll lock and unlock a freshly tamped puck and see what it looks like. I suspect this is a problem, but I hope I'm wrong. It seems reasonable to me to dose a heap of coffee in the PF, level off, and tamp, shouldn't produce a puck that "massacres" the showerscreen when locked in. Otherwise it seems difficult to level off any sort of dose of coffee. No tapping or any other way to overdose is being used, just heaped on there, leveled off, and tamped.
Scale needed. Maybe I'll go get one today, just to erase this as a variable.
buzzmc
Link to "Getting started with the Vibiemme DoubleDomo Super"by cannonfodder on Wed Apr 23, 2008 3:56 pm
A level sweep across the basket should get you in the 16-17 gram range if I remember correctly, and again provided the basket/portafilter/group is the same as the Domobar Super which I believe it is. When working on headspace, I will put a nickel atop the finished puck, lock in and then remove. If the nickel is mashed into the coffee, I dose down more. I did a blurb about it when working on the bench article for the Domobar Super and single baskets.
cannonfodder
Link to "Getting started with the Vibiemme DoubleDomo Super"by erics on Wed Apr 23, 2008 6:25 pm
buzzmc wrote:. . . and even on my over-tamped 12bar 40second or so shot.
Somebody (your dealer) should have set your machine up with a Scace II Thermofilter such that it produces a 200 F, 1.75 to 2.00 ounce shot with 9.0 bar at the portafilter. They could even have included a nice, hand written, thank you note saying that "This is how we set your machine up BUT feel free to play around from here. And, oh, by the way, here's how you do that . . .
If your brew pressure gage is hitting 12 bar, something's wrong - as far as I'm concerned. The "regular" Vibiemme is pretty stable from a temperature standpoint:
Skol,
Eric S.
erics
Link to "Getting started with the Vibiemme DoubleDomo Super"by buzzmc on Wed Apr 23, 2008 7:53 pm
erics wrote:Somebody (your dealer) should have set your machine up with a Scace II Thermofilter such that it produces a 200 F, 1.75 to 2.00 ounce shot with 9.0 bar at the portafilter. They could even have included a nice, hand written, thank you note saying that "This is how we set your machine up BUT feel free to play around from here. And, oh, by the way, here's how you do that . . .
<image>
I see a {small} business opportunity here... which, if someone in the bay area has said Scace/etc, which I assume can't be cheap, and wants to help dial in my machine, I'm sure we can work something out... Part of the reason I bought this machine was to stop worrying about some of these things.
buzzmc
Link to "Getting started with the Vibiemme DoubleDomo Super"by cannonfodder on Thu Apr 24, 2008 12:17 am
The Domobar Super is very temperature stable. When I was working the bench testing I ran 4 or 5 shot tests with the same recovery/flush timing. Every shot ended at the exact same temperature, down to the tenth of a degree. I would imagine the double is just as stable.
cannonfodder
Link to "Getting started with the Vibiemme DoubleDomo Super"by buzzmc on Thu Apr 24, 2008 1:06 am
This is what I anticipate with the DoubleDomo... Stability. So what you've just said is good news indeed.
The only real issue is this business about the PID reading some 14-18*F lower than the brew group temp... And I suppose I somewhat understand why VBM would hesitate to build in the differential, since indeed each installation location would make a 'hard coded' differential inaccurate, and it's probably costly to figure out a way to make that correct all the time, at sealevel, vs 5000 feet, etc.
So I'm now after a way to find out what number on the PID produces a 200*F brew temp... Then I'd know my "baseline" for my machine, location, etc.
While I'd really like the display to read the brew temp, at least if I knew what I had to set it to to get what I want, I'd know what I was working with.
I'm sure I'll get close with trial and error testing and results in the cup. I'm currently set at 219F, trying to get a 203* brew temp. I produced one shot tonight with the 219 setting that was outstanding... So I have to be close.
buzzmc
Link to "Getting started with the Vibiemme DoubleDomo Super"by cannonfodder on Thu Apr 24, 2008 8:56 am
Our bench test machines are around a month off yet so I cannot add much to your request/observation. Once they do arrive I plan on spending countless hours playing with the PID and data-logging on the Scace. I will say that for several years I did not have a thermofilter, I simply adjusted all the parameters by taste, then when the Scace arrived I used it to confirm my taste test adjustments. For now, follow what the cup is telling you.
cannonfodder
Link to "Getting started with the Vibiemme DoubleDomo Super"by stefano65 on Thu Apr 24, 2008 6:50 pm
Based on the initial response from U.S. customers, Vibiemme has decided to modify future productions of the DoubleDomo to better meet the American market's needs. These changes are specific to the US market due to limited amperage, UL certification, and transportation issues.
In Europe, with a 2200 watt limit, we can use a 1200 watt heating element and a higher-range pressurestat to supply sufficient steaming capability. In the United States, UL certification requires a pressurestat with a lower setting. In addition, to keep an amperage below 15, we are limited to 1600 watts, which means a smaller heating element. When designing the DoubleDomo, we had to choose between greater steam volume or greater steam-boiler recovery time. Initial consumer feedback tells us that greater volume is preferable. Therefore, we will increase the size of the steam boiler to the same size as the brew boiler to improve the capability, which also means a slight increase in recovery time.
Due to the delivery system in the United States, we will also reinforce the structure of the DoubleDomo. In Europe, units are palletized and shipped with couriers for shorter distances, whereas in the U.S., shipments are boxed and continually loaded and unloaded between trucks and hubs as they travel great distances.
Based on the above, future Vibiemme DoubleDomos sold in the U.S. will arrive with a larger steam boiler and reinforced structure. As already explained to existing customers, the units currently in the U.S. will be retrofitted with a larger boiler. Replacement parts are already on their way from the factory, and owners will have the choice of receiving the necessary parts and completing the modification on their own or sending the unit into a factory-approved technician.
Jim with 1st-Line equipment welcomes you to visit their booth at SCAA in Minneapolis, May 2 - 5, 2008, booth 1416, where the latest version of the Vibiemme DoubleDomo will be on display and available for testing. A second unit is on its way to Stefano's Espresso Care in Oregon and will also be available for hands-on testing.
Stefano Cremonesi
stefano65
Link to "Getting started with the Vibiemme DoubleDomo Super"by DavidBB on Thu Apr 24, 2008 7:32 pm
So, with this new development, would it be better to wait for the reinforced structure or will the old model with new boiler be ok? Will there be a visual difference between the two on the outside?
DavidBB
Link to "Getting started with the Vibiemme DoubleDomo Super"by Beezer on Thu Apr 24, 2008 8:00 pm
stefano65 wrote:Due to the delivery system in the United States, we will also reinforce the structure of the DoubleDomo. In Europe, units are palletized and shipped with couriers for shorter distances, whereas in the U.S., shipments are boxed and continually loaded and unloaded between trucks and hubs as they travel great distances.
I read this statement to mean that the machine needs to be reinforced because of the shipping problems within the US, not the shipping from Europe to the US. In light of the problems we all experience with UPS, I think this is a good idea.
I also think it's very cool that VBM and 1st Line are willing to recognize the steam boiler problem and have worked out a fix for it so soon. The fact that they are going to provide the fix as a (free?) retrofit to those customers who already bought their machines is even better. While it would have been preferable if there had never been a problem in the first place, I'm still very impressed that the manufacturer and distribution have stepped up and taken care of the problem so quickly. Kudos. Other companies could learn a thing or two about customer service from these gentlemen. (Cough - La Marzocco - cough!)
"There are no stupid questions, only stupid people."
Beezer
Link to "Getting started with the Vibiemme DoubleDomo Super"by 1st-line on Thu Apr 24, 2008 8:31 pm
Beezer wrote:I read this statement to mean that the machine needs to be reinforced because of the shipping problems within the US, not the shipping from Europe to the US. In light of the problems we all experience with UPS, I think this is a good idea.
The current design of the machine does not sustain any damage when shipped within Europe - this was the basis that Vibiemme made their design on. Stefano's Espressocare and 1st-line did voice the concerns for shipping within the USA.
There is no damage when shipped from Italy to the USA as these are shipped on pallets in a sea container. The problem is that here in the good ol' USA, the processes of conveyor belts and slides (at the major common carriers) that can reach 150 ft or higher cause inertial forces which can shift components inside the machines - this is not just Vibiemme, but all brands across the board.
The retrofit of the steam boiler will be free. All existing customers have the option to self-replace, or the dealer/distributor/1st-line would pick up the machine for the retrofit to be installed.
Jim Piccinich
1st-line Equipment, LLC
1st-line
Link to "Getting started with the Vibiemme DoubleDomo Super"by stefano65 on Thu Apr 24, 2008 8:48 pm
DavidBB wrote:So, with this new development, would it be better to wait for the reinforced structure or will the old model with new boiler be ok? Will there be a visual difference between the two on the outside?
Visually, nothing will change. The frame will be thicker, as Jim pointed out, to withstand our "friendly" US shipping companies. Inside the machine, the steam boiler will be larger (details posted above).
1st-Line and Stefano's Espresso care have been working for the last 3 years to introduce the quality of Vibiemme to U.S. consumers, and we will continue to work hard on shipping issues and design improvements to better meet the needs of our customers and not let minor glitches interfere with a very good quality and well-built machine.
It's time to go home for the day... more to come...
(This means you too Jim... it's even later on the east coast... is the sun already rising there?)
Ciao, Stefano
Stefano Cremonesi
stefano65
Link to "Getting started with the Vibiemme DoubleDomo Super"by buzzmc on Thu Apr 24, 2008 9:08 pm
So I just finished adjusting my grinder, and managed to pull a shot with the PID set at 221F, the pressure gauge reading 9.5/9.6 during the pull, and volume about right, but really blonde crema, and fairly bland taste.
This was also after adjusting the OPV down to 9.7or so.
I'm stumped at what to try next. Fresh coffee and these parameters, I would think, should produce a reasonable shot at the very least, not something off the charts in some direction.
More info... Nothing that's concrete, just observations.. The espresso in the cup isn't as hot as I would think it should be, so it has me wondering if something's off... I just touched the grouphead however, and it's plenty hot, so I don't think it could have anything to do with this thermosyphon stuff I'd read about.
Last observation that I think is meaningless (but maybe not).. The pucks after brewing are much wetter than that of my Andreja Premium... Often times with a small pool of water on top of the puck.
buzzmc
Link to "Getting started with the Vibiemme DoubleDomo Super"by HB on Thu Apr 24, 2008 9:31 pm
buzzmc wrote:So I just finished adjusting my grinder, and managed to pull a shot with the PID set at 221F, the pressure gauge reading 9.5/9.6 during the pull, and volume about right, but really blonde crema, and fairly bland taste.
Crema is lighter if the temperature is much too cool or there's channeling. One quick way to confirm the temperature without involving thermofilters / thermocouples is to raise the temperature - significantly - say at least six degrees F. That should produce a very dramatic change (e.g., dark, oily crema with black halo; bitter cocoa and harsh roast notes).
buzzmc wrote:Last observation that I think is meaningless (but maybe not).. The pucks after brewing are much wetter than that of my Andreja Premium... Often times with a small pool of water on top of the puck.
That means there's a goodly amount of puck-to-dispersion screen clearance, nothing more. For your baskets, that's probably around 14 grams. You could add another gram if you like, but I think the Vibiemme performs best with traditional Italian doses.
PreviousNext
Return to Espresso Machines
