This has probably been posted but I haven't found it.
My M4 stepless will arrive today. To save some time I'd like a hint at where I might start the grind settings, i.e. with my Rocky dialed into zero, I was usually grinding in the 9-10 range. Can someone give me a rough idea of where to start?
Climb14er wrote:I received my Macap MC4 dozerless/stepless earier today. I followed the directions and got my zero point which equals to #5 mark.
arossphoto wrote:What are you lining the #5 up to, since the M4 has no alignment mark on the body? I've had the M4 stepless for a week and I've placed a mark in the center of the hopper on the very front of the machine to use as my alignment mark. I've been testing a few different beans and somewhere between 7 and 7.5 seems to work well for me.
Andrew
Andrew
Climb14er wrote:So my question still is: marks (on the dial) or (full) numbers to move to the starting point from the zero point?
HB wrote:If I remember correctly, the espresso range is about 1/8th turn above the zero point (where the burrs touch). You can confirm the zero point by first running the grinder empty, then turning it off and rotating the collar until the burrs touch (again, the grinder does not need to be running and the chamber must be empty). Grind a sample and pinch it between your fingers. It should feel much coarser than flour, but less coarse than salt. The grinds should stick together slightly; if the beans are fresh and the grinds don't adhere together, it's too coarse. If the grinds hold a fingerprint impression, it's too fine.
