Getting the most out of Starbucks Barista while saving for upgrade
Link to "Getting the most out of Starbucks Barista while saving for upgrade"by Ryan_A on Wed Dec 20, 2006 6:31 pm
Hello All,
I'm new here and have a couple of questions. I have a starbucks barista machine and I have a Mazzer Mini on the way. I am saving up for the La Val semi-auto. I have worked at a couple of coffee shops in Nor-Cal and learned more about espresso after I stopped being a 'barista'. (Go figure) I have read about some mods for the Starbucks barista and I have done a few.
Here is what I have done: I have removed the spring to deactivate the pressurized part of the the PF. I have also tweaked the screen on the grouphead to get the water to be dispersed evenly.
I have also read that some people use a awl or other device to make the hole bigger on PF below the basket. Is this something that will make better shots?
I also ordered a RB tamp but I think I may have sized it wrong. I measured the bottom of the basket for the measurement and I got the tamper and it fits like a glove, but it is about 1.5mm less than the top diameter of the basket. I think I should have a tamp that fits the top of the basket and not the bottom, am I right?
Also...I have read that people have purchased saeco non-pressurized PF's that fit the machine, but I only see other pressurized PF's on the websites. I would like to purchase a better PF for the machine.
If anybody out there has experience with these machines and has found other ways to get the most out of it please let me know. I really want to upgrade...very badly, but I just need to wait a little longer.
I live in the Sacramento, CA area are there any people on the forum that know great places to get espresso in the area? I Peet's is the only place in Folsom that I have found that can actually pull a decent shot. I have only lived in the area for a short while and I could use some advice as to where I can get some great coffee.
Sorry this is a sporatic thread, I am just getting ready to go to work and I wanted to post something to hopefully have some replies when I get home.
Thanks a bunch in advance for replies. I look forward to using all the information to finally get some great espresso at home (when i upgrade my machine).
Ryan_A
Link to "Getting the most out of Starbucks Barista while saving for upgrade"by erics on Wed Dec 20, 2006 9:13 pm
Firstly, Welcome to HB.
I am going to, more than likely, go against the grain here. I wrote the first review of this machine on CG back in January of 2000 after using it for a couple of years - OK, no big deal. This machine was a workhorse and always came through using the pressurized PF.
The machine does have an over-pressure valve (OPV) attached to the pump but it is not adjustable and is set at a fairly high pressure. The machine also has a spring-loaded check valve just above the screen that serves to reduce the pump's pressure and keep the boiler from leaking while heating up.
I remember the machine working just fine with the pressurized PF as long as you let it warm up about 30 minutes and pull a shot or two through an empty PF before loading it. It performed very well for its price range. But, if you still want to stick with a different PF, here is a potential source for those and loads of other parts for the Starbucks Barista:
http://www.partsguru.com/default.html
Eric S.
erics
Link to "Getting the most out of Starbucks Barista while saving for upgrade"by Kristi on Wed Dec 20, 2006 10:04 pm
Welcome!!!
I had an Estro Vapore (identical machine). It was fine until it started to overheat. Had I known about PIDs at the time, I probably would have PID'ed it and kept it for a while longer.
How long you let it warm up will depend entirely on your particular machine - experiment with 5min, 15min, 30min and see which you like best. The taste difference will be obvious.
Leave the pressurized pf as is. Any attempt I made to mod it made the coffee noticeably worse.
Starbucks says don't tamp. Kristi says tamp a bit - 10-15 lbs - the tamper you have should be just fine.
Soupy grounds: pull your shot, then steam your milk, then remove the pf - the grounds will be a lot less soupy.
ENJOY!!!
Kristi
Link to "Getting the most out of Starbucks Barista while saving for upgrade"by Epuppylove on Wed Dec 20, 2006 10:50 pm
Hello,
I am also new to this. I purchased my *$ barista recently. I did not like how the shots came out. I also read about others purchasing the nonpf so I did some research on line and found two websites: 1st-line.com (sells for around $30) and partsguru.com (sells for alittle more.) I just ordered one from 1st-line. I also read about the naked pf, called espresso parts and they said they did not have a pf that fit the machine. I found a la spaziale that was 53mm (on 1st-line.com), does anyone know if that fits this machine, I would like to try it out. How do you tweak your machine? Since I am fairly knew to learning how to brew my own espresso...what is PID? (LOL)
Thank you
Happy Holidays
Epuppylove
Link to "Getting the most out of Starbucks Barista while saving for upgrade"by Kristi on Wed Dec 20, 2006 10:55 pm
btdt laspaz will not fit a saeco or solis machine - the pf wall is way too thick.
Kristi
Link to "Getting the most out of Starbucks Barista while saving for upgrade"by HB on Wed Dec 20, 2006 11:38 pm
Epuppylove wrote:Since I am fairly knew to learning how to brew my own espresso...what is PID?
From this forum's FAQs and Favorites you'll find a Good all round explanation of PID stuff. The short answer is it's electronically controlled brew temperature.
Link to "Getting the most out of Starbucks Barista while saving for upgrade"by Ryan_A on Thu Dec 21, 2006 4:44 am
Thanks for the welcome and the information.
I have not had bad luck after taking the pressure inducing mechanism out of the PF. I have noticed that the crema is more realistic but a little less than with the Pressurized PF. The shots are also more viscous and it makes me feel like the shots are better just because of the better mouthfeel. I checked that website out and they don't have the nonpressurized PF, but they do show a picture of it. Hmmm?
Ryan_A
Link to "Getting the most out of Starbucks Barista while saving for upgrade"by iiifrank on Thu Dec 21, 2006 10:46 am
Ryan_A wrote:I have not had bad luck after taking the pressure inducing mechanism out of the PF. I have noticed that the crema is more realistic but a little less than with the Pressurized PF. The shots are also more viscous and it makes me feel like the shots are better just because of the better mouthfeel. I checked that website out and they don't have the nonpressurized PF, but they do show a picture of it. Hmmm?
If you're in the USA, email me or PM me your mailing address and I'll send you the saeco non-pressurized PF I used with my Barista. Even though I've moved on, I still love the machine since it's where I learned to pour latte art and make palatable espressos. :) I think I owned mine for nearly two years before upgrading and never had a single problem.
PS: Unfortunately, it's the uglier gray PF since the black version was always out of stock. :)
iiifrank
Link to "Getting the most out of Starbucks Barista while saving for upgrade"by jesawdy on Thu Dec 21, 2006 11:21 am
FWIW, I think pressurized portafilters are the devil :twisted: .
I have heard several people mention that they ordered a Saeco non pressurized portafilter direct from Saeco USA for right around $30. http://www.saeco-usa.com/
My brother has the Starbuck's Barista, and I think it is a decent machine to start out with if you can find a deal on one. He has the Starbuck's (Solis) grinder as well. He only uses the non-pressurized portafilter and currently has a cheaper 49 mm metal tamper that he uses to tamp the coffee... it works, but I know he wants a proper tamper.
I would caution you to be sure all the monkey business in the bottom of your modified (de)pressurized portafilter is cleaned... I think it would have a tendency to traps lots of gunk and possibly go rancid.
As for the tamper you have, it should work fine. Do a Staub style tamp (NSEW). I know one of the problems with Saeco machines is that it might take a 52 or 53 mm tamper depending on the baskets/machine/date of manufacture.
Report back when you get your Mini, I think you will be pretty happy with the Barista for awhile longer.
Jeff Sawdy
jesawdy
Link to "Getting the most out of Starbucks Barista while saving for upgrade"by espressoyum on Sun Jan 21, 2007 6:05 pm
I've been happy with my pressurized filter until recently. I just started roasting my own beans and the pressurized filter creates too much crema. I can't get a full extraction. iiifrank, if nobody else took you up on your non-pressurized filter offer, I would love to take it off your hands.
espressoyum
Return to Espresso Machines
