torretta wrote:Is there another way to drain the boiler without needing to undoing this fitting ? I undid this fitting to let air into the boiler so it can be drained using the drain plug on the side of the boiler.
why not just open the water wand valve? On my old vibe machine, which has the drain plug on the absolute bottom of the boiler, I remove that and it drains fine without opening any valves or removing any fittings, but given the placement of the drain on the newer machine, if you use the plug on the side you may need to open the water wand or steam valve.
Alternatively, as Jeff Sawdy suggested in a post recently, you could just unscrew the vacuum breaker valve and then go in with some tubing and siphon out from the bottom of the boiler that way. I'll try that when and if I have to drain the boiler of the rotary machine. With the vibe, the drain plug placement is so convenient, there is no reason to do anything other than removing the drain plug at the bottom.
For anyone devoid of common sense reading this, please note: Before you drain the boiler of any espresso machine, you should do the following in this order:
(1)
TURN OFF THE MACHINE THEN UNPLUG IT FROM THE WALL
(2) Drain as much water as will come out directly from the water wand
(3) Wait until the machine cools down to the point where water coming out will not burn your skin (or anything else)
(4) be prepared for what will happen when the residual water comes out, e.g. have a place to drain it, protect any electrical wiring, brain boxes, other circuits, that might be exposed, and have some rags around for mopping up, just in case.
ken
