Hey, guys. Been a lurker here for a while, but have decided to join
. I have ordered a Gaggia Carezza and Le'Lit PL53, and they should arrive in a couple weeks (as the Carezza is on backorder). I do have experience with espresso, though. I currently work at my local indie coffee shop. That's how I got into espresso...and here I am, ordering my own equipment.
stevier wrote:Yeah, fits most any gaggia from the 90's (80's?) and up.
Looking at WLL's Compare-O-Matic, the Gaggia Baby, Baby Twin, Baby Class, Classic, Carezza, and Coffee ALL are listed as having a "back-pressure relief valve." According to WLL, a back-pressure relief valve is:
WLL wrote:Back pressure relief valves serve two important functions. First to ensure that your machine does not brew above the proper "brewing pressure". If the brew pressure is too high then you will get a bitter and overextracted beverage. Also, it protects the pump, gaskets and seals from excess pressure. This feature works by bleeding off water in the boiler to either the reservoir or to the drip tray. All of our machines have this feature.
My question is: Is this "back-pressure relief valve" the same as the Gaggia OPV (or ANY OPV) on Ebay?
Asked another way: How does the "back-pressure relief valve" compare with an OPV?
I may just have to wait until my Carezza comes, then open it up and see what's in there. If this "back-pressure relief valve" is NOT the same as that OPV, then I will most likely end up buying that OPV, because I am interested in making the best espresso I can with that little Carezza
FWIW, I'm planning on installing a PID to it soon.
