EspressoGirl wrote:1)I have recently bought this machine and pulled 10-15 shots but of the 5 holes that water comes through in the grouphead, 2 of the holes have a smaller stream (one of those 2 goes from having a little stream to no water coming out of it sometimes). Once there was a shower of extemely skinny jets of water coming out when I ran water through it with screen on. Recently, I took the screen off and made sure it was clean. It wasn't clogged at all. How can I fix this problem?
Have you unbolted the dispersion block and checked for any clogging through there? That involves unscrewing the two hex screws you see once you remove the shower screen. Before that, try running the pump with the shower screen removed and check the flow through the center screw hole. Then, put the screw back in (but not the shower screen) and see if the flow is even from the two or four holes (don't remember how many) in the dispersion block. If there is even flow through there, then check your shower screen again for clogged holes (hold it up to light - I'm sure you've done this already) or check if it is not a fairly uniform gently sloped dome-like shape.
EspressoGirl wrote:2)Also, no matter how many times I bleed the steam wand, water always comes out, so water is getting into my milk I am steaming. Again, how can I fix this?
After you're done pulling the shot, be sure you're waiting about 30 seconds and beginning to steam before the ready light turns on. (You should time how long it takes for your machine's ready light to turn on and on subsequent steaming sessions purge about 4 seconds before that time elapses and begin steaming 1-2 seconds before the time elapses. This way the boiler stays on and it will take longer to run out of steam, as the boiler is helping you along the entire way.) The first blast of steam will always sputter a bit but should even out after a brief blast. While steaming I've found it most effective to open the valve all the way and once I get to 140 degrees I know it's time to crank it back closed. I am not certain whether the valve is "full open" after a single turn or not.
EspressoGirl wrote:3)Does anyone know if the Silvia wand is the right size to fit in a Classic Gaggia if I want to replace the short steam wand it came with? (Any other wands fit?)
Thanks and I appreciate all advice.
The Silvia steam wand fit my Gaggia Espresso and I've seen it (online) on a Gaggia Coffee - I think the classic should be similar. The only difficulty with the replacement is removing a nut from the old steam wand - I had to crank mine into a vice and bend the wand to get the nut around the bend. I've gotten much better results with the new wand. (But now I've upgraded to a different machine - the Gaggia served me quite well for the time I had it and was an excellent learning tool.)
Good luck and please post the results - I'd be happy to hear if any of this info made sense or was useful.
