Free Medical Advice
Want to talk espresso but not sure which forum? If so, this is the right one.
Link to "Free Medical Advice"by bernie on Tue Mar 25, 2008 3:48 pm
It has been discussed a zillion times, so let this be one more testimonial to the medicinal qualities of caffeine. After several days of fighting an increasing cough, sneezing and raspy-sounding breathing my wife insisted I go see a doctor. He happened to be a regular customer and confirmed what my wife knew from decades as a nurse. Pneumonia. During the history-taking the doctor asked me what were the symptoms. That afternoon I'd developed a whale of a headache. It hurt more than all the other symptoms combined. The doc asked if I'd been eating and drinking normally and when I said I'd lost my taste for coffee and had only been drinking juice he looked at me like I was an ijit. Which I was at that point. He just kept staring at me as it slowly dawned on me that the medicine I needed most was the caffeine fix. A million times I'd advised folks not to abruptly stop caffeine unless they wanted a whale of a headache. So, again I say, keep up the regular medicine like caffeine when you get ill lest you be an ijit like me in front of your doctor.
Bernie
bernie
Link to "Free Medical Advice"by CoffeeOwl on Tue Mar 25, 2008 4:33 pm
When I don't have my morning cup I get asthma very soon. Best is to follow the breakfest cup with an americano and then another in accompany of a tasty lunch.
'a a ha sha sa ma!
LMWDP #199
CoffeeOwl
Link to "Free Medical Advice"by Beezer on Tue Mar 25, 2008 5:46 pm
I always get a headache if I don't have my daily dose of caffeine. But I'm not an addict. I can stop anytime I want. I just don't want to.
There's an interesting article in Wikipedia about caffeine tolerance and dependency.
Tolerance and withdrawal
Because caffeine is primarily an antagonist of the central nervous system's receptors for the neurotransmitter adenosine, the bodies of individuals who regularly consume caffeine adapt to the continual presence of the drug by substantially increasing the number of adenosine receptors in the central nervous system. This increase in the number of the adenosine receptors makes the body much more sensitive to adenosine, with two primary consequences.[55] First, the stimulatory effects of caffeine are substantially reduced, a phenomenon known as a tolerance adaptation. Second, because these adaptive responses to caffeine make individuals much more sensitive to adenosine, a reduction in caffeine intake will effectively increase the normal physiological effects of adenosine, resulting in unwelcome withdrawal symptoms in tolerant users.[55]
Other research questions the idea that up-regulation of adenosine receptors is responsible for tolerance to the locomotor stimulant effects of caffeine, noting, among other things, that this tolerance is insurmountable by higher doses of caffeine (it should be surmountable if tolerance was due to an increase in receptors), and that the increase in adenosine receptor number is modest and doesn't explain the large tolerance which develops to caffeine.[56]
Caffeine tolerance develops very quickly, especially among heavy coffee and energy drink consumers. Complete tolerance to sleep disruption effects of caffeine develops after consuming 400 mg of caffeine 3 times a day for 7 days. Complete tolerance to subjective effects of caffeine was observed to develop after consuming 300 mg 3 times per day for 18 days, and possibly even earlier.[57] Partial tolerance to caffeine has been observed in all other areas, studies with mice indicate that after a long period of caffeine exposure the learning benefits of caffeine observed earlier cannot be found to any significant level. Considering that 80% to 90% of American adults consume caffeine daily, and their mean daily caffeine intake exceeds 200 mg/day,[58] it can be surmised that a large fraction of the U.S. adult population is completely tolerant to most of the effects of caffeine.
Because adenosine, in part, serves to regulate blood pressure by causing vasodilation, the increased effects of adenosine due to caffeine withdrawal cause the blood vessels of the head to dilate, leading to an excess of blood in the head and causing a headache and nausea. Reduced catecholamine activity may cause feelings of fatigue and drowsiness. A reduction in serotonin levels when caffeine use is stopped can cause anxiety, irritability, inability to concentrate and diminished motivation to initiate or to complete daily tasks; in extreme cases it may cause mild depression. Together, these effects have come to be known as a "crash".[59]
Withdrawal symptoms—possibly including headache, irritability, an inability to concentrate, and stomach aches[60]—may appear within 12 to 24 hours after discontinuation of caffeine intake, peak at roughly 48 hours, and usually last from one to five days, representing the time required for the number of adenosine receptors in the brain to revert to "normal" levels, uninfluenced by caffeine consumption. Analgesics, such as aspirin, can relieve the pain symptoms, as can a small dose of caffeine.[61] Most effective is a combination of both an analgesic and a small amount of caffeine.
This is not the only case where caffeine increases the effectiveness of a drug. Caffeine makes pain relievers 40% more effective in relieving headaches and helps the body absorb headache medications more quickly, bringing faster relief.[62] For this reason, many over-the-counter headache drugs include caffeine in their formula. It is also used with ergotamine in the treatment of migraine and cluster headaches as well as to overcome the drowsiness caused by antihistamines.
So caffeine actually causes real physical dependency, and you will suffer from fairly unpleasant withdrawal symptoms if you try to quit cold turkey.
"There are no stupid questions, only stupid people."
Beezer
Link to "Free Medical Advice"by ppopp on Tue Mar 25, 2008 7:09 pm
My heart doesn't start beating in the morning until I get my first cup. Truth.
Peter
Know beans, know coffee. No beans, no coffee.
ppopp
Return to Knockbox
