The larger dose shots were pretty much all bound for the sink. Regardless of the distribution method or tamp I got shots like this...
Severe blonding and uneven extraction on the front of the group. Now most of these are extreme examples, the last photo is what I would call a drinkable reject. I do not have any shots of the reduced volume to show in comparison. Each of those shots used different distribution techniques, NSEW, Weiss, modified Stockfleth, and the Chicago Chop. The latter of which tended to supply the best result. I gave the PF a couple of downward thumps on the forks of the Mazzer while dosing, which is how I jammed in so much coffee into the basket using each technique.
I would also tamp with the PF handle in different orientations. That way if it were me favoring one side of the tamper, the over extraction point would move, but it was always in the same position. I would even favor the front during the tamp and dose in an attempt to compensate but still got the same result or a completely choked shot.
Once I down dosed back to 17g and increased the head space, the extractions started to even out. Still not perfect, but better. One observation, once I engage the pump, I get a rapid beading on the bottom of the PF. In about two seconds I have a series of pearls across the bottom of the basket, then it pauses for another couple of seconds, then it starts to extract. The rapid beading on the bottom of the basket is part of why I started this thread and pointed to the high volume of water. The high flow rate is pounding the top of the puck instead of giving me a slower, more uniform preinfusion.
