skyryders90 wrote:Does that WHOLE grey piece come out? Or just the part that the red plug is in?
Yes, the whole grey adapter comes out. Press on the bigger (lower) grey rim. The quick connects are sort of like those "Chinese finger cuffs" -- the harder you pull, the tighter they get. To release them, there must be no water pressure. Then press down firmly on the rim. It doesn't give much, maybe 1/8", but trust me, they'll let go.
BTW, keep the adapter in case you want to tee off a 1/4" facet line from the 3/8" tubing.
skyryders90 wrote:Thanks Dan - is there a reason that setup has it exiting the FloJet with 3/8 and connecting to the Andreja as 1/4?
No, that just happen to be the connectors I had handy since the rest of my filter system is 1/4". I've since installed a second 3/8" system for test machines. If I were to do it again, I'd go 3/8" all around. At the time I figured a couple ounces isn't enough to get excited about, but I wasn't considering bigger machines with high flow rate rotary pumps. Ooops.
