by denniskeating on Sun Nov 13, 2005 4:18 pm
Sean,
I need help understanding how to install the new OPV and at same time hooking up new (3/8"?)direct plumb in line.
I would need to put the OP valve on a tee coming out of the boiler tee, wouldn't I? Then my incoming water line would also connect to the OP Valve tee?
I'm thinking that by not using the stock OP Valve, my adapter & water hook-up fittings will be different. I am also taking out the vibe pump, and adding external Procon w/ 1/2hp motor, and good water filters.
Also, is there concern for a strain relief or grommet where the external water line enters the machine?
Thanks, Dennis
