She ( as was obvious in the photo posted on Ebay- is sporting a steamer lid-without the handle, just the stud that screws into the center tube- double nutted- steam tube is ok but.. where to find a handle? !!The nuts are so nice and " shade tree" styled
My new step up transformer only came with a twp prong receptacle- Radio Shack here I come.
After disassembling her for the basic clean out I found all the seals to be very pliable and in great shape. Even the flapper valve washer in the group head wash very new feeling( brass screw in center a free turning jewel)
There were remnants of some loose silt-like scale deposits found in the base of the kettle, but it washed off with a tooth brush. No weeping from the hole in the front of the base!! All in all I am happy with the machine ( it has been at least 40 minutes
To get my cursory first doppio, I had to boil water and fill the kettle to pull my shot, it was not too disappointing.
One thing -Timo- or others- I assume that the larger o-ring that peeks out from under the dispersion screen is the PF gasket? Here is why I ask, After reassembling "the screen, o-ring, the other dispersion plate followed by two metal washers over the valve area" I found that the PF is way, WAY too tight to insert the bayonets and do the 1/4 turn into the grouphead??? It could be the wrong o-ring in the first place or I could be missing something. I find it odd on an old machine that parts are hard to find for, from Italy that this o-ring would be this tight. I don't want to force the PF till I can get a little dialogue from you or others. The shot I pulled didn't leak and pulled Ok with me just adding boiling water to the kettle, flushing and pumped handle etc. After putting in the lugs , I can only get the PF to turn about 1/3 the total travel from inserted to fully seated. No where near straight to my belly button?
Any thoughts( I will re-read your redux while recharging the camera)[/img]
