by Makanmata on Sat Feb 09, 2008 5:32 pm
My new Mini Vivaldi II from Chris arrived after some minor shipping snafus. I was able to set it up today, and play with it a bit.
My first impressions are overall pretty good. Firstly, the machine has much more heft and presence than I had realized, and really does give off the aura of a small commercial machine, rather than that of a big home machine. I'll have to get used to what I feel are a bit too many plastic bits, but in all, the machine looks and feels substantial and solid. Noise was a big concern of mine, and nearly led me to try the Alex Izzo rotary instead, but I must say that this is the quietest vibratory machine I have ever heard, and while I still wish I had a rotary pump -- maybe for no good reason -- I can't say that the Mini's pump is annoyingly loud.
The machine does seem rather easy to use. None of my dozen or so (Black Cat) shots this morning were bad, although while some of them looked terrific, with very substantial amounts of crema and striping, I was not particularly thrilled with the flavors I am getting yet. I suspect that some of this will come with adjusting the temperature, which arrived set at 93, but which seems a bit low, no? What temperatures are you all using? Steaming is very impressive, and in a different league than my old Giotto.
The only possible out of the box quality issue I have noticed is that the gauge that doesn't seem to be working correctly. More specifically, the left group gauge dips all the way to the minimum point until the pump is engaged, and jumps up (though still in the blue zone) when the pump is turned on. To be frank though, I'm not exactly sure what this is supposed to be measuring, or what the proper measurement is, so maybe it is working correctly? The steam boiler part of the gauge seems to be working fine. My only other problem is that I can't find a blind filter in the box. Is it supposed to be included?
So, in general, I'm feeling pretty positive about my purchase. I look forward to hearing any suggestions anybody has regarding the proper temp settings. Thanks.
