Bushrod wrote:I think I'm mainly just having dosing/grind/distribution/problems. I'm getting really uneven extraction with my Silvia. I'm grinding to 11 on the Rocky DL with two scoops of beans. 12 is too fast and 10 or 9 is too slow.
How much volume are you getting from your shots and how long does it take?
I moved from the bottomless/triple to the bottomless/stock double basket this morning. Tasted a lot better. I think I'll try to dose it some more tonight. It goes blond pretty quickly on the right side.
I think that is a good move. I've had a hard time getting even extraction with the triple basket. You might want to continue using the bottomless PF so you can see if you are still having problems, though. I think there is a slight taste difference between the naked and a regular PF and prefer the stock model, but the naked is good for checking your extractions. It definitely sounds like you have some distribution problems if the flow is blonding in one area very quickly. If you haven't already, you might check out the
Tamp and Dose Techniques Digest. There's a lot of useful information there. Many people are fans of the Weiss Distribution Technique (WDT for short). Personally, I've used it some but prefer to use a quicker method and practice to get consistent results. Best of luck!
Justin
