Abe Carmeli wrote:Regardless of whether I use a flat or a convex piston, Stockfleth or Schomer distribution, I notice that the first moisture to appear at the bottom of the basket is around the perimeter. From that point it gradually spreads to the center. We are talking about a second or two, not 10 seconds. There is no channeling in the shot, and judging by the beautifully cohesive puck after the knock, the saturation in the puck is even.
Question is - how does that pattern of progression affect the shot? Do you ever get simultaneously even moisture at the bottom of the basket, and if so, have you notice an improvement in the cup?
I had that problem with one of the baskets on my Techno. Turns out, to make the story short, that the basket in question had a more bowed bottom than the others. When I put the basket in question upside down on the counter, put a piece of hardwood on the top, and hit it with a mallet, it made the bottom flat and the extraction then began evenly across the bottom. And yes, it did taste better; that's my story and I'm sticking to it.
Best,
David
