The Expobars do run hot, but if you're willing to flush more water, it's manageable.
The Expobar Lever I tried out had a large flush (6-8 ounces) and very fast rebound (only 15 seconds, IIRC), but I quickly adapted to its preferred flush-n-go technique (see Jon's
Water flushing and "knowing" your HX machine for details). Apart from the large volume flushes, the only other "drawback" of the flush-n-go technique (compared to the flush-rebound documented in
HX Love) is that your margin of error is smaller. Flush an ounce too much or delay 10 seconds too much and your temperatures are off. That's why some refer to flush-n-go as the "pro's method", i.e., because it's the requisite technique for commercial HX machines, which recover in seconds, not the leisurely pace of semi-commercials we're discussing.
If I've not convinced you to adapt your technique and put off adjusting the pressurestat, see the picture below:
Yellow cap and two wires exiting near top of boiler
(red dot is paint blob covering the adjustment screw)
As you might guess from the semi-permanent seal, the manufacturer is suggesting you don't touch. You'll need a pressure gauge. I've read accounts of using an ordinary tire pressure gauge, a length of rubber brake tubing, and a couple clamps over the steam arm to measure. Make certain the tubing can take the heat! I think the Expobar is typically set to around 1.0 bar and I've heard of owners turning it way-y-y down to 0.7 bar. That may be acceptable if you don't mind wimpy steam.
Regulating the brew pressure is slightly more complicated without the convenience of a portafilter pressure gauge. First, this is the Expobar's expansion valve (OPV):
Jim Schulman's
Adjusting vibe pump pressure on HX machines explains the mechanics, including the diagram below:
(reproduced with permission)
You can guesstimate using his runoff technique, or
build a pressure gauge. A setting of around 9 bar is a good start.
