Europiccola woes...I'm not getting water into the group.
A haven dedicated to lever espresso machine aficionados.
Link to "Europiccola woes...I'm not getting water into the group."by Madroaster on Tue Nov 15, 2005 12:14 am
Hi All,
My Europiccola is sick, and I'm not sure where the problem lies. Basically, water doesn't always enter the group like it should. Sometimes it goes in normally and I get good flow, other times I get a trickle, and sometimes I get nothing at all. It's a problem that's getting progressively worse. Needless to say, my coffee's suffering, and thus I'm suffering.
In essence, when I raise the lever and get no water, I keep lowering and raising until I get some. Sometimes it takes several times to get any. The piston should be traveling as far as it's supposed to; the lever itself doesn't impede it at all, and it's not on upside down.
I use filtered water for the machine, and it's only a few months old. It seems to heat the way it always has; it's never run dry or anything like that. I'm wondering if there isn't some sort of buildup along the intake tube, or some blockage going into the group itself.
I clean it pretty regularly, and pop the dispersion screen off about every 2 weeks for a good cleaning. The only maintenance I've been lacking on is adding new lubricant to the shaft, and I've got some of that on order.
Suggestons?
Madroaster
Link to "Europiccola woes...I'm not getting water into the group."by Madroaster on Tue Nov 15, 2005 10:20 am
Solved... The piston had loosened on the rod. I tightened it up and it works great.
Madroaster
Link to "Europiccola woes...I'm not getting water into the group."by srobinson on Sun Nov 20, 2005 12:10 am
Give this a look about every 6 months. Common problem.
Steve Robinson
LMWDP #001
srobinson
Link to "Europiccola woes...I'm not getting water into the group."by Madroaster on Tue Nov 22, 2005 10:50 am
srobinson wrote:Give this a look about every 6 months. Common problem.
Will do. Mine's barely 4 months old, but it sees pretty heavy use (7-10 shots/day).
Madroaster
