(I merged your question with a topic on the same subject).
JavaJunkie wrote:I believe these are both Italian products, so presumably they are ready for 220V. Can anyone confirm that? Will I simply be able to put an adapter on the plugs and plug straight into an Australian power outlet?
If it were only so simple. Computers may have "universal adapters", but not espresso equipment.
I used a step-down transformer when I lived overseas in Europe and most appliances worked. Kitchen appliances with a heating element worked fine, appliances with motors ran slower than normal. Electronics was a mixed bag (e.g., radios worked fine, clocks that depend on the frequency didn't). In your case, a large step-down transformer would do the job. Allow a good margin of error on the wattage, otherwise you'll blow fuses (especially for the surge when a motor starts up, e.g., a vacuum cleaner).
Tip: Contact expats living in Australia before leaving, you may be able to work out a cheap exchange on non-transferable appliances with those departing around the same time you're arriving.
