I may be wrong but if the boiler pressure is controlled by a pressure stat then the "frequency difference" should not effect the pressure because the p-stat turns off the power when the boiler reaches the p-stat setting.
To make certain I have emailed someone in "Down Under" who should have the answers to your questions. I will keep you informed.
Cheers
Geoffrey
