Most of my experience has been with non HX machines- levers. I have owned a Silvia, TEA and a Livietta( HX intro) and still have a couple of Astra Gourmets. They all are a little different.
Most of the high points on HX have been touched on. If you are more anal by nature, you will not relax till all the bases are covered. Thats OK - it is your machine. Others will do it another way.
Levers- Since backflushing is not an option I:
pull a shot, knock and then re-insert PF, and pull another water only shot.
Remove PF using a folded Papertowel or equal wipe the PF gasket and wipe the dispersion screen.
Done
Every week or so- I actually use a group-head brush and brush the PF gasket.
Once a quarter- I'll flip off the dispersion screen and ( with the machine not on and hot) raise the lever or / lower depends on which machine, and do a simple wipe out of the cylinder with some Cafiza and hot water. Scrub the screen. Yes , I know that flipping off my Cremina's screen with out taking the grouphead off was warned about by Steve R. and proper care should be excerised if yours is stubborn- My screen pops off easily, always has. It just seems silly to do a big operation to check the cylinder.
Once a year ( maybe pull the PRV off on the bigger machines) and look inside to check out if any de-scaling is required. If so a tbsp of Citric acid ( bought bulk at a beer / wine making store) to a 1/2 gallon of water or mixed to your specs. Fill up the boiler, bring to temp, run some shots, steam, draw water and let it sit for about an hour. Drain flush - drain flush. Refill , bring to temp and pull shots and run all water , stream venues till all clear
I live in a "good water " area. I use a brita pitcher, keep the filter changed. After a year I have no detectable scale in any thing I own. Good for me - some of you will have crystals forming in a month... sorry.
When I took the astras apart ( they were from St Paul MN) they were scaled!! But the citric acid works charms on everything. Faucet sets, group heads, boilers( 5 L) lines etc. Cafiza and boiling water or just warm water soaked any old PF's etc back to sparkling clean.
I use 0000 steel wool for cleaning PF and chrome and polished stainless steel. It seems to leave ZERO swirls and not degrade the chrome on PF after repeated cleanings. I find that the green scotchbrite pads are too abrasive for most of the bright-work.
I also have never gotten real upset about some boilers not being plated and other having nice nickel plating inside. Most of the water lines in the world have been made of copper( versus old galvanized . teracotta and others) and most good quality alcohol stills are made of copper( they run at the same temperatures and run for a long time with no altering of flavors- I speak from experience onthis point- I ahve been distilling quite a while). I have noted that many here find that they start to find plating in their PF baskets and get very concerned. While visually alarming I don't think it is as big a issue as it seems. I do know that frequent use of descaler will remove plating from the inside of boilers very quickly.......... Won't it Richard
What you should do about it when it happens to you is another good topic to discuss.
It is late , I have wandered and digressed. Shutting up But that was a nice Fiesta Bowl Game........................!!
