I have lived in Los Alamos, NM during the summers for the last 3 years. It's at 7200 feet, as I recall. At any rate, water boiled around 197F, at atmospheric pressure. It took some getting used to. The first 2 years I had a La Valentina, and then the 3rd year I had gotten rid of Valentina and bought a La Pavoni Professional. That was actually easier, I think, altitude-wise. Honestly, I don't think that you will see a serious difference in the quality of your espresso. I got plenty of beautiful shots from both of my machines out there.
Now, of course water will boil at atmospheric pressure at a low temperature (around 195F for you, I think). But remember that espresso is under very high pressure in the puck. So you shouldn't have any issues with flash boiling on the puck.
The issue I had with an HX machine is that flushing is significantly more confusing. You may have to stop the flush before the water dance ends up that high! I would suggest flushing by volume rather than the water dance, and try to develop something consistent around that, OR get
Eric's thermometer adaptor.
You might consider looking for coffees that favor lower brewing temperatures, but honestly, I don't think you should need to. You just need to play around with your routine a little, I think--vary the flush, and maybe the dose. You might also drop the boiler pressure down a little bit.
