www.vanelis.com: top-notch espresso equipment and customer support
Entering the lever world - cleaning 101?
A haven dedicated to lever espresso machine aficionados.
Link to "Entering the lever world - cleaning 101?"by LeoZ on Thu Jun 28, 2007 4:12 pm
as i sit in an airport, as usual, awaiting delays, my elektra microcasa a leva is sitting in my garage, awaiting my arrival. (i pray its in good shape!) so, i figure i should learn the intricacies of a lever machine.
as far as pulling a shot, i think its straightforward -
-13 minute warmup
-quick flush (2oz?)
-lock and load, using a much finer grind than used for hx machines
what about cleaning and maintenance? after the pressure settles (30secs-1min?) you can release the puck, right? can you backflush? do lever machines have a 3 way valve? if not, how does everyone clean it?
what about sight glass? easy to open to clean out or change? gasket and shower screen - same as hx as far as frequency?
thanks for the help, and keep your fingers crossed that ebay didnt send me a lemon!
LeoZ
Link to "Entering the lever world - cleaning 101?"by frege on Fri Jun 29, 2007 2:03 am
LeoZ wrote:as i sit in an airport, as usual, awaiting delays, my elektra microcasa a leva is sitting in my garage, awaiting my arrival. (i pray its in good shape!) so, i figure i should learn the intricacies of a lever machine.
-13 minute warmup
-quick flush (2oz?)
Please note that before you do ANYTHING make sure the boiler has enough water in it- between 1/4 and 3/4 full according the the sightglass. This is an essential part of your brewing pattern- you can't forget to make sure your water level is adequate. Some mistakes aren't crises; that one is.
Warmup can take as long as 13-15 minutes or few as, well, very few, depending on how cold the machine is; adding cold water to the tank (which Elektra recommends) will of course slow things down a bit too, but I've never had to wait more than 14. As you get more familiar with the machine you'll be able to tell when the pressure valve on top stops hissing- at that point the needle starts to move up (assuming your needle isn't gummed up with scale) very quickly. To speed things up I do this "flush" (draw an ounce of so of now-very-hot water through the brewhead and PF to warm them up) when the needle reaches, say, .5 bar- this saves me maybe one or two minutes, which matter sometimes!
Much finer grind? Where did you learn this? I do use a grind (depending on the bean of course) that's a little bit finer than what I used on my pump machine, but certainly a "much" finer grind and you'll choke the machine. If you DO choke it, which has happened to me only once, turn it off, bleed the pressure off through the steam wand, and wait a while to detach. I've never read any tips on this but releasing all pressure seemed like a good route to take and eventually the lever did return to its starting position.
Wait at least a minute after the lever's returned to starting position to remove the PF. I think all EMCaL owners have experienced portafilter sneeze despite our best efforts but I think at least a minute is the minimum prudent standard. If you hear anything when you're removing the PF, stop and move it sloooooowly. I have to add, and I don't mean to scare you, but if your PF is not properly seated or if it's not pushed in all the way and you either start a shot or even pull water through for that initial group warming (ie with the filter empty), you run the risk of the PF blowing off the grouphead with a force that is just terrifying, shattering whatever cup you might have underneath the thing, blowing off the showerhead, and very possibly injuring yourself. I've managed to do this twice and I hope never will again- nobody warned me about this- you have now been warned. You're welcome.
No, you cannot backflush this machine. You can clean the showerhead with a "portafilter wiggle," with a grouphead brush (don't use this brush with the scalding hot boiler water- think of it like you'd brush your teeth- oh and don't use a grouphead brush on your teeth either), or even, depending on your kitchen, by putting your baby in the sink and blasting the screen with your faucet extension hose thingie. I personally have found the showerscreen very easy to remove and clean on its own, too, and I do this once a week or so. There is no screw; you can pry it off carefully with a screwdriver (a flat head, natch).
I'll defer to others on the sightglass removal question.
There are of course other maintenance issues regarding piston maintenance and gasket replacement, but you can find those if you poke around here, and in the shorter term, I think you have most of what you need to know now.
You've purchased a great machine. I've had mine since April, and I'm a convert. I must add that you're going to be very impressed with the steaming capability (assuming you will be having cappos and other milk-based drinks)- my microfoam is consistently good and sometimes damn near perfect, and I can steam while the shot is pulling- without having to futz with any other knobs or paying any attention at all to the shot- the lever is doing the work. Few machines allow this sort of capability.
frege
Link to "Entering the lever world - cleaning 101?"by msmith on Fri Jun 29, 2007 8:32 am
Hey Leo,
You're in for some fun! I've had my MCaL only a month now, and I look forward to our meetings every morning. You've got to start somewhere with a reference point, why not start with the coffee / grind combo you are using now with your ECM? My experience so far has me grinding two steps finer (sometimes one) than I would use with my Rancilio, but tamping somewhat lighter.
When evaluating your shots during dial in, listen to what your mouth is trying to tell you. Your lever shots may not be as crema - laden. But they may taste spectacular nonetheless.
I know you know this, I know everyone knows this, but let me say it again anyways. HOT. MCaLs and Elektra Semis get HOT. But isn't good coffee worth a little pain?
msmith
Link to "Entering the lever world - cleaning 101?"by augustusflavius on Fri Jun 29, 2007 4:40 pm
The cleaning process I use on the Elektra is; after extraction/steaming I wait approx. 1 minute and slowly turn the portafilter clockwise until I hear pressure releasing, then I tighten again. Repeat until all pressure is released. This only takes about 10 seconds. Put empty cup under grouphead and depress lever until water flows, couple seconds. Wipe out the grounds with a paper towel. Then I take a bulb syringe, this type http://www.med-worldwide.com/product1234.html, and flush the bottom of the grouphead. This does a good job of flushing the grounds. Sometimes I also take a Q-tip to it as well.
augustusflavius
Link to "Entering the lever world - cleaning 101?"by LeoZ on Fri Jun 29, 2007 9:22 pm
thanks everyone, for the advice.. after a LONG commute, im finally home, and was able to open her up and tinker. the machine appears to be in great shape. :D always a good thing! started up perfectly, warmed up no problem, and ran some water through, then pulled 2 shots. yes, both were terrible. im guessing not fine enough of a grind. should the lever pop up within 10 seconds? i assumed it would be slower.
also, 3 more questions:
-whats normal boiler pressure? mine seems to be hovering between 1.5-1.75bar. i assume this to be high, since its in the red zone, not the 1-1.25green zone.
-is there a recommended operating pressure? wheres the pressurestat hiding? underneath the machine?
-how long, after 2 shots, should i let the machine stay shut off for? till its completely cooled? should i drain the water all the time?
looks like ill use the weekend to see what this machine can do..
LeoZ
Link to "Entering the lever world - cleaning 101?"by frege on Mon Jul 02, 2007 1:23 pm
"Normal" is the white space between green and red, which I guess is 1.25-1.5 bar, but I can pull a shot when it's at .8 or lower (ie when I turn the machine off to temp surf)- not that this would be seen as ideal. When you say yours sits at 1.75 or whatever- are you sure the needle returns to the bottom when the machine is cold? I've read that it's quite common for the needle to stick; maybe in this event it shows a false high reading, since it doesn't start at "true zero"? I dunno.
You don't have to wait for the machine to be completely cool to pull more shots- in fact I like to use it when it's warm (not hot) because it's a quick start-up. However, warm or hot or cold, you MUST make sure all pressure is purged before you refill the boiler. You can drain pressure through the steam wand (look for the needle to return to the bottom and no more steam to come out) or by holding the lever down so all the water escapes. The former method will not empty the tank, just purge pressure.
I sometimes drain the tank completely en route to cleaning, get all the grounds and residue and such out. I don't do it all the time.
frege
Link to "Entering the lever world - cleaning 101?"by LeoZ on Mon Jul 02, 2007 5:19 pm
frege wrote:"Normal" is the white space between green and red, which I guess is 1.25-1.5 bar, but I can pull a shot when it's at .8 or lower (ie when I turn the machine off to temp surf)- not that this would be seen as ideal. When you say yours sits at 1.75 or whatever- are you sure the needle returns to the bottom when the machine is cold? I've read that it's quite common for the needle to stick; maybe in this event it shows a false high reading, since it doesn't start at "true zero"? I dunno.
thanks for the reply.. i actually made a lot of headway this weekend. took it apart, except for the boiler itself. everything was dirty! cleaned the 'grouphead' copper line, cleaned all gaskets, shower screen,etc. man, this thing was dirty! i may let some citric acid sit inthe boiler just to make sure its clean as well.
also adjusted the pressure down. 1.5bar and up seems to make too bitter of a shot. relative of course, to an hx machine. i think ill start a separate thread about that.
LeoZ
