The Elusive Clarity in the Cup
Discuss flavors, brew temperatures, blending, and cupping notes.
Link to "The Elusive Clarity in the Cup"by AndyS on Wed Jul 13, 2005 10:31 pm
(mod's note: Moved from Bricoletta's Bench thread)
malachi wrote: I checked brew pressure on the machine and it was higher than I like (10.25BAR). But I didn't really want to bother with it. Today I decided to suck it up and dial the brew pressure in to where I like it (right between 9BAR and 9.25BAR).
So even with the Flojet pressure variations (described in the "Flojet and rotary pump questions" thread), with this setup you are able to dial in the brew pressure and maintain it within 0.25 bar?
malachi wrote:I got it dialed in and pulled a shot of the Hairbender that was all I wanted it to be. Dense, rich, heavy in chocolate but with all the fruit and acidity desirable. Layered and complex but with great definition of flavour.
Wow!!
And Hmmm...
After some more work I had an idea. I did a quick re-plumb to get rid of the FloJet and the water filtration unit. Clarity gone. I then hooked up the FloJet without the water filtration unity. Ah Hah!!! Clarity still gone!! Excited now, I replumbed with no FloJet and no filtration and logged brew pressure. Flutter!! Same with the FloJet and no filtration!! And then with the FloJet and the filtration unit... No Flutter!!!! And clarity!!!
So... new theory (just waiting for Jim or Barry or someone to disprove it) is that it's the combination of brew temp profile and consistent brew pressure profile that creates this clarity.
In trying to understand your theory...do I understand you correctly that you are talking about two distinct pressure parameters:
1. brew pressure profile, a curve that defines the nominal brew pressure value through the course of a shot
2. brew pressure flutter, a description of the fraction-of-a-second water pressure vibrations produced by the pump?
Concerning flutter, vibe pumps produce their eponymous pressure waves at 60 hz. Rotary pumps produce pressure pulses each time a vane passes by the outlet pipe. This works out (in N America) to be about 115 times a second (115 hz).
It's possible to greatly reduce flutter using a "water hammer arrestor" (part number 2522K14 at Mcmaster.com). Also, running the brew water through a gicleur reduces flutter.
-AndyS
AndyS
Link to "The Elusive Clarity in the Cup"by malachi on Wed Jul 13, 2005 11:47 pm
With this setup, I was able to maintain pressure to a tolerance of more like 0.10 BAR. Keep in mind that I'm isolated from the water lines so no changes due to flushing toilets or the like and that I have a rather large water filtration canister inline.
Actually, I'd say there are two parameters and one "condition".
1) starting brew pressure (how consistent and accurate is the brew pressure at the time a shot starts - also could be called inter-shot brew pressure consistency).
2) brew pressure profile (what is the brew pressure over time during the extraction of the shot - also could be called intra-shot brew pressure profile or the like)
Condition - rapid oscilation in the pressure during a shot. In other words, is there "flutter" in the brew pressure profile or is it stable through the profile (or along the profile).
I think that there are probably going to be a number of effective strategies for managing brew pressure and the pressure profile over the course of a shot on various kinds of machines and on various pumps. And I think they're going to be very important.
malachi
www.eccocaffe.com: custom coffee roasted in Northern Italian style
Link to "The Elusive Clarity in the Cup"by AndyS on Thu Jul 14, 2005 6:40 am
malachi wrote:I think that there are probably going to be a number of effective strategies for managing brew pressure and the pressure profile over the course of a shot on various kinds of machines and on various pumps. And I think they're going to be very important.
The Versalab machine addresses the problem of managing brew pressure with an active control system. John Bicht told me that he was shocked to find that changes of 0.1 bar made a difference in flavor.
It really isn't that difficult to PID the pressure loop on your espresso machine using existing technology. This would give you the ability to accurately "sculpt" the profile if you wanted the pressure to rise or decline during a shot. Currently the implementation is relatively expensive, but if everyone insisted upon having this, the price would go down considerably.
Meanwhile, installing a water hammer arrestor to reduce "flutter" is dirt cheap. I've got one on my machine, but I haven't played with it in a while. Your comments have made me itching to compare results with and without it. I'm just not sure that the difference will be discernible amid the "noise" of my amateur dose/distribution techniques.
-AndyS
AndyS
Link to "The Elusive Clarity in the Cup"by malachi on Thu Jul 14, 2005 11:17 am
That's an interesting point.
I wonder where the threshold is. Honestly, I expect that trying to manage (in some way) your brew temp profile and brew pressure profile is going to result in some amazing results for a lot of people.
I had three shots this morning... clarity. In all three.
It feels so good.
What is interesting is that either, alone, seems to have minimal results when it comes to this ellusive and desired attribute. Temp stability without pressure control doesn't result in it and pressure control without temp stability doesn't either.
In addition, I've noticed that the so called "flutter" is greater with the FloJet and no filtration than without the Flojet or filtration. But even with the latter there is no clarity.
Today I'm going to go and check out espresso from three different Mistrals. One isn't temp modified and doesn't have any sort of pressure "isolation", one is temp modified by doesn't have isolation and the third has both.
malachi
Link to "The Elusive Clarity in the Cup"by malachi on Thu Jul 14, 2005 11:53 am
A definition of "clarity"...
The experience of tasting an espresso blend and being able to taste not only each bean in the blend, but all of the component flavours of each bean - and having each flavour be clearly defined on the palate.
Imagine a range of colours all together and seeing each colour distinctly rather than having the colours blended together into a flowing gradient of browns to greys.
This is not to say that "clarity" is a required attribute for good tasting espresso. It's an abstract concept and one that I honestly don't know matters to a lot of people.
malachi
Link to "The Elusive Clarity in the Cup"by malachi on Thu Jul 14, 2005 8:39 pm
I'm working on tweaks to brew pressure to see what the results are. One thing I'm beginning to note is that it is possible (perhaps even likely) that there is going to be an optimal pressure profile for each coffee just as there is an optimal temp profile for each one. Now that I've said it it seems downright obvious and I'm sure millions of people have thought of it before.
But it's new to me in the sense that not only is the stability and accuracy of the profile required, the degree of accuracy required is quite fine indeed.
Given the inherent lack of control in the (very manual, very mechanical) adjustment of brew pressure, experimentation is proving to be time consuming.
malachi
Link to "The Elusive Clarity in the Cup"by AndyS on Fri Jul 15, 2005 5:56 am
malachi wrote:A definition of "clarity"...
I think I know what you mean. At the 2004 SCAA show I tried coffee from the Versalab machine. Afterwards, I wrote this comment on alt.coffee:
As far as the flavor goes, the word that came to mind was "transparency." It
seemed like you could look into the blend clearly and taste whatever was there
to be tasted.
Sadly, they screwed things up at the Seattle SCAA, and the coffee was nothing special.
-AndyS
AndyS
Link to "The Elusive Clarity in the Cup"by AndyS on Fri Jul 15, 2005 6:06 am
malachi wrote:I'm working on tweaks to brew pressure to see what the results are. One thing I'm beginning to note is that it is possible (perhaps even likely) that there is going to be an optimal pressure profile for each coffee just as there is an optimal temp profile for each one.
Just a related point to throw into the discussion: in my experience, the speed with which the pressure ramps up at the beginning of the shot is a significant part of the pressure profile. This isn't regulated by the Procon pump itself, it's regulated by using a gicleur or a needle valve downstream of the pump. On my machine, a near-instantaneous pressure rampup (as on many gicleur-less Linea AV machines) required a coarser grind adjustment (to maintain shot timing) as compared to the grind needed with a more gradual (~4 sec) pressure rampup.
-AndyS
AndyS
Link to "The Elusive Clarity in the Cup"by malachi on Fri Jul 15, 2005 11:12 am
Excellent point.
I think all the machines I've experienced this "clarity" on either have a slow ramp up through some pre-infusion methodolgy or have downsized to the .8 or even .6 jet.
malachi
Link to "The Elusive Clarity in the Cup"by MOSFET on Tue Jul 19, 2005 11:21 am
I'm sure this has been asked before, but why do you guys use a tank and flojet before the pump to keep it stable rather than a simple pressure regulator?
thanks
Keith
MOSFET
Link to "The Elusive Clarity in the Cup"by malachi on Tue Jul 19, 2005 12:06 pm
If the machine were connected to the mains I would have an accumulator (static tank) to regulate pressure.
malachi
Link to "The Elusive Clarity in the Cup"by MOSFET on Tue Jul 19, 2005 1:48 pm
malachi wrote:If the machine were connected to the mains I would have an accumulator (static tank) to regulate pressure.
My question is why a static tank plus flojet instead of a just a single pressure regulator?
MOSFET
Link to "The Elusive Clarity in the Cup"by malachi on Tue Jul 19, 2005 1:57 pm
You are right.
The FloJet is (in this case) due to the machine not being plumbed but rather run from a 5 gallon bottle.
malachi
Link to "The Elusive Clarity in the Cup"by MOSFET on Tue Jul 19, 2005 2:10 pm
malachi wrote:You are right.
I see. When I first read about the concept in David Schomer's book I wondered immediately why he didn't just use a regulator. The only guess I have is a regulator will not prevent severe underpressure, which I assume is quite rare. It will only limit overpressure.
Keith
MOSFET
Link to "The Elusive Clarity in the Cup"by malachi on Tue Jul 19, 2005 6:14 pm
You don't want to merely limit line pressure. You want to instead control it. You want to eliminate any fluctuation in line pressure into the pump (in other words). Thus the Schomer solution or the static tank (air pressure accumulator) solution.
malachi
Link to "The Elusive Clarity in the Cup"by HB on Tue Jul 19, 2005 6:21 pm
First a clarification for those who are following along...
    Static tank: essentially a float valve keeping a tank partially full from which the pump draws water. Its purpose is to assure a constant inlet pressure.
Correct? And a comment... if one is that concerned about incoming micro-pressure variation, I would eliminate the pressure regulator if only to avoid the "valve chatter" as the flow rate slows, or a Flojet, which introduces its own pulses.
But this is definitely "extreme espresso gear" territory.
Link to "The Elusive Clarity in the Cup"by malachi on Tue Jul 19, 2005 6:36 pm
Two options:
Schomer Option - A tank with a float valve from which the pump draws water.
"Other" Option - A pressurized tank (usually using a bladder and air pressure) which provides positive pressure to the tank.
The goal of both is to isolate the pump from any fluctuations in inlet water pressure.
I would predict that neither are worth doing unless your pump is capable of producing non-fluctuating brew pressure (and you or the machine are capable of managing brew temp profile to be correct and consistent).
malachi
Link to "The Elusive Clarity in the Cup"by PureArabica on Mon Jul 25, 2005 11:28 pm
AndyS wrote:This would give you the ability to accurately "sculpt" the profile if you wanted the pressure to rise or decline during a shot.
What if, you hooked up some kind of "flowcontrol" pedal. Like an accelerator.
just a thought,
nick
Nick Griffith
Intelligentsia LA
PureArabica
Link to "The Elusive Clarity in the Cup"by AndyS on Tue Jul 26, 2005 12:48 am
PureArabica wrote:What if, you hooked up some kind of "flowcontrol" pedal. Like an accelerator
That would be nice, but I'd rather have a sensor hard-wired to my nervous system. That way, I could have the pressure ramp up and down using will power. I mean, why not? :-)
-AndyS
AndyS
Link to "The Elusive Clarity in the Cup"by PureArabica on Tue Jul 26, 2005 7:31 pm
Ooooohh... CREEPY!!
You could go all Sci-Fi with that! There could be a certain "breed" of people created just to extract perfect espresso with their minds.
:wink:
Nick Griffith
Intelligentsia LA
PureArabica
Next
Return to Coffees
