...merged additional details with existing thread on same topic by moderator...
I've been living with the Silvia for about 2 months now -- long enough to get to where I can pull a halfway decent shot about half of the time
My main complaint about the Silvia, and one that I've occasionally heard about it any many other of the vibe pump machines is that it is just too noisy. It seems especially noisy at 6AM when everyone else is trying to sleep.
I had some leftover adhesive backed sound dampening material from
http://www.mcmaster.com (see page 3360). After removing the top and the splash panel of the Silvia (6 screws total) I cut pieces of this material and stuck it to the inside of every stainless surface that I could easily reach. It doesn't take a lot but even a 2"x2" square stuck behind the Rancilio logo on the front of the unit cuts down the vibration.
If you cant come up with enough places to use up a 32" x 54" sheet of sound deadening material, head out to your local car stereo store and get a 12" square sheet of Dynamat -- same idea but you pay extra for the branding. These products are heavy, often asphalt based, self adhesive sheets that you stick to the inside of your trunk, hood, doors, floors, and any other panel that vibrates sympathetically with whatever is vibrating. Same theory with the Silvia -- stop the stainless panels from vibrating and you'll cut down the noise. If you tap on the top of the Silvia with your finger, you can hear it resonate. Now place your palm on the top panel and then with the other hand tap on the top again -- the drumming is minimized.
The Silvia is MUCH quieter. I don't have a thingy to measure decibels, but its certainly at least half as noisy.
Hal
