I've got a couple of ideas that I thought I'd throw out. As long am I'm taking the machine apart to clean it up, why not do a couple of simple changes along the way.
1. Insulate boiler
So I've read the Buyers Guide To the Elektra (that's why I now have one).
It suggests insulating the boiler which I think is a great idea.
See
http://www.coffeegeek.com/forums/...chines/78392#783922. Change pressure stat to one will a smaller dead band.
Why not drive a nice zero crossing SCR mounted low in the chassis from a Mater pstat (smallest dead band)?
This came about after reading Paul Pratt's review of the three main p-stats.
http://www.espresso-restorations.com/p-stats.html3. Use an SCR to drive the boiler.
Well, a zero crossing SCR is used in my QM Anita and it does a fine job. Get one rated at say 50A and I'm set.
http://www.digikey.com/scripts/Dk...l?name=646-1011-NDWhile I'm at it, I have another question for all you Elektra owners that have insulated their machines:
4. What would you think of running at 2/3 of the boiler power?
I don't plan on every hosting a party where I pump out 30 drinks in a row, heck 4 is the most I've ever done.
The reason I'm asking is that the boiler appears to have 3 heating elements running in parallel. If I insulated the boiler I may not need 2000 watts of heat, 1330 (or so) is probably plenty and now the machine can be run at 15A instead of need a dedicated 20A circuit.
5. Additional changes, put a steam/drip catcher on the vacuum breaker just in case it gets stuck open.
6. Soft mount the pump.
Erics in suggests that a soft mount for the pump instead of hard copper connector will help deaden the transfer of sound.
rotary-pump-hx-espresso-machines-their-sounds-t6869.htmlMark
