The real issue though is once this occurs the system attempts to build up some steam and you kind a hear a leaking noise.
The steam wand (which is new) and the water wand which I re-built both leak under pressure....<ARGHHH>.
Mark
mhoy wrote:Now to adjust the pressure stat. What are you guys running your systems at???
Oh, and what do the two red lights on the right and left of the group head indicate?
Mark
mhoy wrote:Unfortunately, I'm a ways from getting a nice place inside for my Elektra.A kitchen remodel needs to occur first and working on Elektra is way more fun.
mhoy wrote:The p-stat (which everyone recommended I replace is nicely shown on page 1 by Dave as "I- Boiler pressure release valve". The connection near the boiler goes to the fill solenoid. Take plenty of pictures, I have more if there is a particular item you need a larger/better look at.
mhoy wrote:Sylvain: I didn't have such a connection in my machine, here is a picture from when I was disassembling it. Your comment probably explains why I have a big red wire nut just before the heater....![]()
Mark
cannonfodder wrote:... A high speed car buffer, a dozen buffer bonnets, some heavy cutting compound, white rouge and metal polish like MAAS or Flitz.
