Recently I've got it as used. which manufactured in 2000, sold in Japan. I connected 200V power line and water. As I turned the main switch to "1", expecting pump motor to be moved, but nothing happend, so does pushing brewing buttons. I filled the boiler with water manually with using the lever at the bottom front. Then I turned main as "2" and waited for a few minutes, some noise heard and started to make hot water.
When the pressure gauge indicated green area, I could get steam just right. but still there were no response from the pressing buttons on the front panel. Hot water must come out after turning the knob, which is just a switch for the solenoid valve, works nothing.
I have checked pomp motor and every solenoids with directly giving 200V and they works.
I've also checked brewing switch panel with tester, disconnecting the connector, and they are just fine.
I pulled out main electric board, only giving the 200V power, the transformer seems working and gives 12V to the output.
I think the problem on this machine seems to be the main electric board, either ROM or related circuit to control relays.
I can NOT spend on a lot of money for replacing the board for the test.
Does anyone help me fixing this problem? With minimum cost?
I am living in Japan, and it is very hard to find a local repair service, plus the cost of each parts is nearly tripled through the agency. For they told me the main board would be around US$1940.
Please HELP me!!!!
