HB wrote:cafeIKE wrote:I had a similar problem on the Vibiemme, but it is due to thermosyphon stall...
Would you elaborate? I've never heard of a "thermosyphon stall."
Dan,
First, let me take this opportunity to thank you for a great forum. Grazie mille!
Perhaps the term is inexact, but as you can see in the graph, the temperature in the thermosyphon drops like a stone. The first time I experienced it, the espresso was so sour, it was unbelievable. Perhaps the most sour in almost 4 decades.
As sour equates to low temps, and the machine was new, the boiler pressure was ~1bar, the Parker was clacking every 150 seconds, 10 on, 140 off, there is almost unlimited steam and the external boiler temperature remained constant about 245°F, I added a TC to the thermosyphon inlet and outlet of the group. The graph posted is but one example of the symptom.
After much consternation, several false starts and help, I happened upon the idea that the only thing that could cause the temperature of the group to drop when the boiler was at temperature was the thermosyphon flow was "stalled." No hot water flow is replacing the heat lost due to radiation from group.
My 'guess' at the cause:
When a short cleaning flush is run, the upper chamber of the group drains into the empty pre-infusion chamber. If the pump runs for only a very few seconds, the upper chamber the does not refill. As there is no drag of the flow exiting the thermosyphon, the thermosyphon enters a resonant state and stalls. No less a luminary than Michael Teahan concurs.
I recently added Eric's TC/TM adapter set and have confirmed that it is possible to cause the group temperature to drop as in the graph at will by running a short cleaning flush after pulling a shot.
The next test is to leave the puck in the PF and run a short cleaning flush just before pulling the shot.
Note : the Vibiemme has a flow restrictor in the upper thermosyphon tube. Before I discovered the root cause, I was prepared to adjust the diameter of the orifice and /or thermosyphon injection point. The point is now moot.
