E61 Group Espresso Machine: Is its reputation justified? - Page 2
Yes
62
69%
No
8
8%
No opinion
19
21%
Total votes : 89
Link to "E61 Group Espresso Machine: Is its reputation justified?"by another_jim on Thu Nov 10, 2005 5:34 pm
Is the E61 the very best head out there -- no. Is the E61 an excellent brewhead by today's standards across the board -- yes. Is it widely and cheaply available -- yes. Is it easy for an amateur to get good shots with it -- yes. Are the two or three better brewgroups widely and cheaply available -- no. Are they easy to use -- no.
The e61 died out as a commercial brewgroup, except for some Spanish machines, by the mid-70s. It made a comeback in high end homemachines with the Giotto and Isomac A1 (the predecessor of the Zaffiro/Amica); and has been reintroduced into commercial machines since then. This is possibly due to the high scores it kept getting versus other catering/home HX machines in tests, or because the average skill level of baristas was (and probably still is) in decline.
I'm pretty sure a WBC class barista will pull better shots with a Synesso or LM; but most of us aren't WBC class baristas, nor do we have $5000 to spend on a machine. Alties who took pains and made better shots than 95% of cafes with Silvias, Gaggias, etc, and then made the switch to one of the e61 machines were pretty unanimous that the shots were better overall, more consistent overall, and easier to pull overall. So I would say that they deserve their current reputation as the brewhead of choice in home machines at this price point.
Finally, it is a beautiful brewhead that instantly communicates that its espresso will be something special; only a large lever group or the LM paddle wheel can compete in this presentation aspect. Any foodie knows that presentation really does make the dish taste better (people just pay more attention). So Italian designers are not at all crazy when they try to make eyecatching and beautiful machines; it increases the appreciation of the shot. So why not make the head a thing of beauty too? I'm sure the new return-to-the-paddlewheel LM group will have a similarly beneficial effect for their perceived shot quality, even of the physical quality of the shots are unchanged.
BTW, about the preinfusion and thermosyphon. Basically both are intended to be tunable. The gicleur and spring tension for the pressure-ramp preinfuse can be adjusted, also the levetta can be raised part way for a lever/LM style trickle preinfuse. The thermosyphon should have an adjustable restrictor. In home machines these parts are unfortunately left out.
The new LM have thermoplastic valves designed to keep the preheat of the brew boiler water at 185F. When this technology becomes more available, the thermosyphon can be set up with a valve to keep the group at 205 or so. It is rumored the new Expobars have this; but I have no confirmation on that.
another_jim
Link to "E61 Group Espresso Machine: Is its reputation justified?"by malachi on Thu Nov 10, 2005 5:40 pm
Out of curiosity, why would you want to keep the group at 205F?
malachi
Link to "E61 Group Espresso Machine: Is its reputation justified?"by lennoncs on Thu Nov 10, 2005 6:19 pm
I believe there is significant additional performance potential in the "E61" group.
Sean
lennoncs
Link to "E61 Group Espresso Machine: Is its reputation justified?"by HB on Thu Nov 10, 2005 6:24 pm
barry wrote:fwiw, there seems to be a common misconception that a "heat exchanger" machine is a "thermosyphon" machine. there are several heat exchanger designs in use on commercial machines which do not use a thermosyphon.
Indeed, a popular prosumer non-thermosyphon HX espresso machine that comes to mind is the Livia 90 (grouphead is bolted directly to the boiler). There are surely others.
malachi wrote:And I believe that the Amica is a thermosyphon machine that is not a HX machine - right?
Yes, as is the Expobar Brewtus and the Quick Mill Eliane.
Link to "E61 Group Espresso Machine: Is its reputation justified?"by barry on Thu Nov 10, 2005 6:31 pm
another_jim wrote:It made a comeback in high end homemachines with the Giotto and Isomac A1 (the predecessor of the Zaffiro/Amica); and has been reintroduced into commercial machines since then. This is possibly due to the high scores it kept getting versus other catering/home HX machines in tests, or because the average skill level of baristas was (and probably still is) in decline.
how well does the reintroduction of the e61 coincide with the exhaustion of the patent?
barry
Link to "E61 Group Espresso Machine: Is its reputation justified?"by another_jim on Thu Nov 10, 2005 6:33 pm
malachi wrote:Out of curiosity, why would you want to keep the group at 205F?
So it's just at the very top of the brew temp range (or at least the range I use - 90C to 96C). That way, I can flush down to any temp I want a bit more quickly than when it sits at around 212 (which is where it's at for my machine)
The big advantage an HX has over a double boiler in home use is that one can get the first few shots at any temperature one wants, provided the group/HX combo is overheated. The trick would be to overheat it just a smidgen, so the flushes are kept reasonably short. On the Tea it's 6 ounces down to 96, 8.5 down to 90. If the head could be kept at 96 or so; it would probably cut the flush by about 4 ounces, since the HX is quite tiny.
Some e61 style designs, notably the astra, have large heat exchangers and wide diameter pipes in the thermosyphon . This is not a good idea, since the system stores way too much heat and requires huge flushes (the astra seems to have so annoyed Greg that he first replumbed it, then bought an LM). The original E61 had a simple pipe for the heat exchanger and very short runs on the thermosyphon; the successful copies have similarly abridged HX designs and use the head for heat storage. Modern HX machines like the Rancilio or Cimbali go the other way, and gave small heads and large bladder like HXs; much of which are in the steam, rather than the water. My guess is if one compares the designs, one would find similar volumes of water overall being heated and being stored away from the heat source.
another_jim
Link to "E61 Group Espresso Machine: Is its reputation justified?"by Teme on Thu Nov 10, 2005 6:33 pm
The Nuova Simonelli Oscar and (at least some of) the Bezzera machines come to my mind. I think that the Livia is actually one of the Bezzera machines, just reclad in slightly prettier covers, but there are also other Bezzera models with HX, but no thermosyphon...
...and the Vibiemme Domobar, which I guess hasn't been widely available in the US.
Br,
Teme
Teme
Link to "E61 Group Espresso Machine: Is its reputation justified?"by another_jim on Thu Nov 10, 2005 8:16 pm
barry wrote:how well does the reintroduction of the e61 coincide with the exhaustion of the patent?
According to Roger, the Futurmat Ariete's first use of the group in '67 was a patent violation. Faema then bowed to the prospect of navigating the Spanish court system (think of South America with a lot of "last of the grandees" arrogance added) and licensed the group to them. It was out of protection by the early 70s. From that point on Futurmat sold it to a lot of Spanish manufacturers, and developed the solenoid version as well which sold even better. However. Roger is not aware of any Italian machines using knockoffs in the 70s or 80s. Grimac was the first Italian company to make a copy, and use it on their catering machines. Again according to Roger, they screwed up the gicleur/preinfusion/dispersion screen on early models around 1990, making it almost impossible to control the flow and leading to a lot of quickly worn out grinders. However, recent Grimac models, like Dan's Valentina, do splendidly. At some point in the 90s, the Rossi group started making one too; and it is found on the Wega, Brasilia, and Vibiemme machines. You know Roger thinks these guys the evil empire, so his take on that head has to be taken with a grain of salt.
I'm not sure if the Vibiemme or the Giotto was the first home machine with the head; but I think the use by Pavoni and Elektra of E61 style heads post dates their introduction.
I have no clue what goes on in Italian espresso manufacturing circles; but the more I think about it, the less I believe the reuse of the E61 has much to do with perceived shot quality. They seem to take the "bad workman blames his tools" attitude on that. Machine design has gone more retro, more sculptural, all round; and the 70s and 80s two box design is going out of style. So my guess is that it may be the visuals of the E61 that is appealing to them. Why build a complicated super designed enclosure, when sticking an E61 and some curvy spouts on a simple box looks just as cool?
another_jim
Link to "E61 Group Espresso Machine: Is its reputation justified?"by AndyS on Thu Nov 10, 2005 8:42 pm
lennoncs wrote:I believe there is significant additional performance potential in the "E61" group.
Yet another cryptic comment from the Lennon skunkworks! :-)
Surely the fact that the 3-way is integral in the E-61 group makes it a better than average basis for further work.
-AndyS
AndyS
Link to "E61 Group Espresso Machine: Is its reputation justified?"by okaychatt on Fri Nov 11, 2005 10:44 am
HB wrote:In this case, the boiler is at brew temperature, not steam temperature
Ok. So a saturated group is found in db machines?
Just when I thought I'd mastered the thermosyphon as solely HX, you two come along.
Ah well - that's the way it goes. The more you learn, the more you realize you don't know.
Kay
okaychatt
Faema "no stop" group, circa 1988
Link to "E61 Group Espresso Machine: Is its reputation justified?"by HB on Mon Nov 21, 2005 6:13 pm
Paul Monaghan (HAL9000) sent me the image below of the Faema "no stop" group and an (imperfectly translated) excerpt that explains its function.
As already written, the delivery group is kept at the right temperature for the delivery of the coffee by means of a thermosiphon circulation. Inside of the group there are three valves:
1) Delivery (72); closed in the rest position.
2) Infusion (73); open in the rest position.
3) Drain (74); open in the rest position.
The group is controlled by means of a little lever, which must be brought from the rest position to the working one (in the semiautomatic machine) or by means of a push button (3) in the case of the automatic one. In this moment, the delivery valve (72) will be closed and the infusion (73) as well as the drain (74) valves will be closed.
During the first 5-6", if the grinding is correct, no coffee is getting out from the spouts, in as much as the hot water is getting in touch with the ground coffee in the filter, but can't flow through because at the beginning the pressure isn't sufficient to win its resistance. The raise of the pressure on the ground coffee is delayed, because of the fact that there is a 0,7mm nozzle, which allows a flow of 10-14cm cubed/sec. of water with a pressure of 9Atm. and an infusion valve together with the infusion chamber below.
At the beginning, just after the group has been commanded, the spaces over the ground coffee are empty and this gives a delay in the pressure raise; as soon as these spaces are filled, the infusion valve opens automatically (roughly at 1,5 bar), giving thus a further delay, necessary for the filing of the infusion chamber, below the valve.
A good infusion can be obtained only with the right grinding of the coffee.
Once the infusion period has been finished (5-6"), begins the delivery of the coffee, which in the half-automatic will be finished by the manual return of the lever to the rest position and in the automatic by the automatic unhooking of the push button. At the end of the delivery, the opening of the infusion and of the drain valves, assures the release of the pressure from the filter holder, so that it can be unhooked without the peril that the dregs explode and hurt the operator.
Paul remarked that the above suggests that preinfusion can be amply explained as "the hot water ... getting in touch with the ground coffee." I like the last line about "exploding dregs" too. :lol:
Link to "E61 Group Espresso Machine: Is its reputation justified?"by HAL9000 on Sat Dec 10, 2005 10:58 pm
EDIT: Just found many discussions on this apparently famous screw. Sorry for the trouble!
Thanks for posting that Dan.
Looking at the diagram, the water path to the filter basket seems to end in two "tubes" - one leading upward at roughly 45 degrees from the horizontal, then the other leading back down at a similar angle into the filter housing.
At the end of the "upward" tube there is a small allen head plug. I can't think of any reason for this to be there except to plug a hole that exists as a manufacturing artifact. Does it serve any other purpose?
If not, has anyone used that hole to place a TC in the group? It looks like a good location to me, especially if you could snake the TC down into that other tube and fix it in the plug in such a way to handle brew pressure.
Thanks,
Paul
HAL9000
Limitations of saturated groups
Link to "E61 Group Espresso Machine: Is its reputation justified?"by mteahan on Mon Dec 12, 2005 5:14 pm
Where an improperly jetted E61 can heat soak after sitting, a LM can lose temperature as there is no effective way for the heat to move through the saturated group. It must conduct heat energy through the water and brass (or SS) in a static fashion by convection. You could make a case for 'ocean thermal gradients' I suppose, but it tends not to work so well in this model.
Older GS groups pulled the water through a jet (sort of) at the base of the boiler, and I understand that this was a better design. I am putting mine together after the first of the year and will take a look. Going to hot rod it, PID, SSR for the steam boiler, trick body, blah, blah blah.
Also, the PI on the E61 doesn't require line pressure to work, it uses the upper spring loaded chamber as a pressure regulator--line pressure may throw off the timing and extraction if not sufficient to open the PI regulating valve.
Also, many companies (not just cheap Spanish knockoffs, which aren't so cheap anymore) have returned to the e61 design. Machining costs are not significantly different between designs as the process is largely automated. The real cost is the material and the finish required. E61 groups are still more expensive than many other traditional groups, especially the manual design.
These include Wega, ECM, Brasilia, Iberital, Expobar, Faema (again), Futurmat, VBM, Pavoni (a few years ago) plus a cast of thousands of upper end home machines. These are current production machines using this group. It has more mass than a saturated group (LM) and, I believe, is more reliable. The people I know who have put these machines side by side, are universally surprised at how much better the E61 performs. At least on commercial products.
JMHO
Michael Teahan
Espresso Part Source
mteahan
Link to "E61 Group Espresso Machine: Is its reputation justified?"by HAL9000 on Thu Dec 15, 2005 8:42 pm
Teme wrote:...Oscar...
Is Oscar really not a thermosyphon machine? I own one and am under the impression it is, in part due to the two pipes from the group that seem to connect to the HX. What would be the purpose of the second pipe if not thermosyphon circulation?
Thanks,
Paul
HAL9000
Re: Limitations of saturated groups
Link to "E61 Group Espresso Machine: Is its reputation justified?"by HAL9000 on Thu Dec 15, 2005 9:50 pm
mteahan wrote:Also, the PI on the E61 doesn't require line pressure to work, it uses the upper spring loaded chamber as a pressure regulator--line pressure may throw off the timing and extraction if not sufficient to open the PI regulating valve.
Hi Michael,
I was under the impression that preinfusion occurs under pump pressure rather than line pressure because the pump is running during PI, but that that pressure is not felt in full force at the puck because, first, the airspace over the coffee must be filled with water and, second, the preinfusion chamber must be filled with water. Only then is the full pump pressure applied everywhere in the brewpath, and the coffee flows from the puck because that has become the path of least resistance. All of which makes me think that pump pressure, not line pressure (and a puck ground and/or tamped to be able to withstand more pressure than the pre-infusion valve), is what is important in timing the opening of the pre-infusion valve.
Wrong?
If not, how could line pressure throw off the timing?
Thanks as always,
Paul
HAL9000
Link to "E61 Group Espresso Machine: Is its reputation justified?"by mteahan on Fri Dec 16, 2005 1:42 pm
Lets say the spring pressure for the PI chamber is set to 20 pounds and your line pressure, perhaps because of a limiting device, is set to 25 pound. The 5 pound differential may be enough to open the valve, but it would also preinfuse the puck and the chamber may be significantly delayed in filling, elongating the PI time cycle. Pump based PI systems (delays) are more predictable when no mechanical PI device is in place. A spring loaded PI chamber ala ECM or Gradisca, ramps up pressure as it extends, but may not extend quickly enough under low line pressure.
The PI systems on E61 heads are designed for full pressure operation, with the ramp and duration assisted by the flow rate set with the jet. PI systems on the old Marzocco GS were pump delay systems like the Synesso. Multiple heads could not be PI'd unless simultaneously done. Which was almost impossible.
The PI simply reduces the initial extraction pressure while the brew temp is elevated and allows for a seamless transition to full pressure once the thermo compensation effect kicks in.
Michael Teahan
mteahan
Link to "E61 Group Espresso Machine: Is its reputation justified?"by eastpresso on Sat Feb 04, 2006 1:04 pm
HB wrote:Lino spent hours measuring his E61 group to input it into his CAD program. Below is one example:
He and I are collaborating on an article to explain in layman's terms how this works. He's working on an animation too. Very cool Lino, thanks! For more pictures, see E61 Group Espresso Machine: Detailed Interior Schematics.
Great thread - here is a link to an E61 animation http://www.benissimo.nl/e61/.
eastpresso
E61 animation gone missing - looking for copy
Link to "E61 Group Espresso Machine: Is its reputation justified?"by eastpresso on Fri Apr 21, 2006 11:52 am
eastpresso wrote:Great thread - here is a link to an E61 animation http://www.benissimo.nl/e61/.
Some might already have noticed that the animation is gone. I posted the link by permission but the site the animation was running on is out of business and Frank (the owner of the animation) does not have a backup copy :shock: If we manage to find someone who has a copy of the animation Frank agreed that (HB's approval provided) we can put it on Home-Barista. This also applies to the animation of the Solenoid (3-way) valve that was running on the same site.
Check the link - if you see an animation you have a cached copy. In this case please PM me.
Bernhard
eastpresso
What is the real fuss about the "superiority" of HX E61 heads?
Link to "E61 Group Espresso Machine: Is its reputation justified?"by j7on on Wed Oct 04, 2006 6:51 am
Hi folks!
Yes, you guessed, time for an upgrade..or is it?
I have been toying around my LaPavoniPro long into my second year now, upgraded the grinder a few times, some minor & MAJOR tweaking of the machine itself, i now roast my own beans, i built a HUGE roaster from a rotisserie style(with the rotating grill-stick inside) oven, i can easily roast 2 - 2,5 pounds of beans in one batch(havent tried bigger batches, oh yes, there is room), i adjust my grinder according to the humidity, learned to use the bathroom scale under the machine etc.
The coffee is now just so GOOD that i have been wondering why i should get a HX/E61 machine?(other than the fact that i just would WANT one..)
I get thicker crema, better mouthfeel, better overall tasting espresso than i have had basically anywhere(small coffeeshops with real baristas working E61 machines), i do not remember when was the last time i had that "Wow, this tastes excellent!" feeling(except my own home)
From what i heard the E61 machines are more reliable to return constant high-quality espresso without "much" effort, obviously i am willing to put alot of effort in learning the trade but would a E61 help me that much more? Would the coffee be THAT MUCH better? Is it really better than anything?
Yes, i have tried some E61 machines and was not that impressed but to make a real opinion i would have to buy one or lend one for a month or so to get see some results.
j7on
Link to "E61 Group Espresso Machine: Is its reputation justified?"by HB on Wed Oct 04, 2006 7:27 am
(I merged your thread with a prior one on a similar subject)
j7on wrote:From what i heard the E61 machines are more reliable to return constant high-quality espresso without "much" effort, obviously i am willing to put alot of effort in learning the trade but would a E61 help me that much more? Would the coffee be THAT MUCH better? Is it really better than anything?
Steve is a long-time La Pavoni owner and has borrowed espresso machines I've reviewed from time-to-time, including an E61. He commented that they were easier, and the crema "so thick you could stand a spoon in it," but he wasn't the least bit tempted to change. I would be interested in hearing your thoughts after a month with any of the E61 espresso machines reviewed on this site.
In my opinion, the E61 isn't "better than anything," but it is popular and well priced.
PreviousNext
Return to Espresso Machines
