barry wrote:the response time on those thermometers is so slow that what you propose really isn't worth the effort.
Barry is correct, the response time on the thermometer is slow. Keep in mind that this little rig is a reference point, not an absolute. I know with coffee X, if I flush down to temp Y, wait Z seconds and brew, I get the best cup. Using that methodology, it does not matter if the thermometer shows 180 or 230, it is simply a reference point. It has ± variable of something like 3 degrees. Based on taste, I think my thermometer ran about 2 degrees high. After all, taste is the final measure of your work.
It worked good for me and provided a reasonable amount of accuracy; it helped me learn the HX flush dance. I don't even use it anymore, I have learned to read the water and hit my temperature with reasonable amount of repetition.
And no the omegalock fittings did not work, but I recycled one into a lever machine and digital thermostat, not a PID, but an old school non logic thermostat so I can easily play with boiler temperatures.
If I were doing it again, I would go with Eric's adapter and a thermocouple, much more accurate, if that is your end goal.
