www.eccocaffe.com: custom coffee roasted in Northern Italian style
E61 brew temperature (Cannonfodder Device) - Page 3
Link to "E61 brew temperature (Cannonfodder Device)"by cannonfodder on Wed Aug 17, 2005 7:27 pm
gscace wrote:If you really want to do this right, buy a probe from Omega or someone similar, use an Omegalok connector, and rather than installing the probe in the bolt that is relatively high on the body of the group, install the probe so that the sensing element is just above the dispersion plate, at the very end of the water passageway before the water hits the plate.
I have two metric omegalock fittings on order, but I do not expect them to fit, but figured I would give it a try. I may even go as far as machining the GH and tap an opening into the chamber like the photos Dan posted.
cannonfodder
Link to "E61 brew temperature (Cannonfodder Device)"by cannonfodder on Wed Aug 17, 2005 7:43 pm
You know, I am glad this little gizmo has generated the amount of discussion and improvising based on the original 'proof of concept' that I made. I have learned more from the discussion of the device and debates about other methods of achieving the same type of data but at a more precise level than I did from building the little gadget. After all, wasn't that the underlying purpose behind Dan's contest, to promote the development of better espresso? I am still hoping to win a grinder (which is why I went through with the idea to start with) but time will tell.
I am having a blast learning about the more technical aspects of espresso, keep in mind I have only owned my own machine for eight months (got my first around December) and have already gone through 4 machines (I still have my lever machine so only two are out of service).
cannonfodder
Link to "E61 brew temperature (Cannonfodder Device)"by barry on Thu Aug 18, 2005 10:35 pm
Strugs wrote:Step one complete. I just picked up a TC meter and a Type J TC wire. I am having my buddy at work run a couple of my A6 bolts through his drill press and seal the TC wire through the bolt with metal epoxy.
i would strongly suggest you use type k instead of type j. j has an iron wire and it will rust on you.
--barry "don't ask me how i know"
barry
Link to "E61 brew temperature (Cannonfodder Device)"by Strugs on Fri Aug 19, 2005 12:25 am
barry wrote:i would strongly suggest you use type k instead of type j. j has an iron wire and it will rust on you.
Actually, that was a typo. I meant K.
The bolt has been drilled. JB Weld is now curing, so my FrE61nkenstein mod should be good to go tomorrow night.
Sean
Strugs
Link to "E61 brew temperature (Cannonfodder Device)"by gscace on Fri Aug 19, 2005 10:05 am
HB wrote:Greg, I assume you won't mind then if I post the pictures you sent me (rescaled)...
External front view
Probe exit above dispersion screen
Did you measure the difference between this location and the E61 channel? Obviously the dispersion screen location is more accurate measure of brew temperature, but I am wondering if the channel is good enough for purposes of repeatability.
In my first iteration I tried installing a probe into the e-61 well above the point that folks are considering. The temperature I was measuring was the temperature of the water flowing in the convection loop set up by the hx and group. This was not close to brew temp, so I learned my lesson and made the measurement as close as possible to the coffee cake. Agreement between my thermofilter and the probe shown in the pix is much better. Putting the probe near the cake gives a much better answer with regard to flushing requirements.
-Greg
gscace
Link to "E61 brew temperature (Cannonfodder Device)"by gscace on Fri Aug 19, 2005 11:12 am
HB wrote:
Abe Carmeli wrote:So, you are facing an unknown: how would it be influenced by the grouphead, especially when grouphead temp varies considerably pending on idle time and flushes.
In theory, a properly tuned thermosyphon holds the grouphead temperature (average) pretty darn close to the target brew temperature. Many people seem to be under the impression that the grouphead temperature is all over the map depending on usage. I've not done anything like Bruce's isothermic modeling, but it seems to me that if you're doing your flushes correctly (i.e., clearing the HX of overheated water and then bringing the group back to temperature from its transitory spike), the grouphead will pretty much "take care of itself." Now if you (stupidly) did half-flushes and waited a little bit several times in succession, I would expect the average grouphead temperature to rise.
Of course, some measurements with the Cannonfodder and Scace Devices on the same machine using a dual logging thermometer would answer this question definitively. However, it is fun to speculate about the results in advance.
Agreement between my probe inserted into the water passage and the thermofilter are very good during brewing.
You touched on a very important point with e-61 groups that is not well understood. The thermosyphon loop operates under certain conditions, and under others, may not operate at all, or may operate backward. for example, if the machine is idle for any length of time, the thermosyphon loop runs in the normal direction. If you flush the group and fill the hx with cooler water, the relatively higher density of cool water in the hx makes the thing run backward since the water in the group is hotter. And if the relative densities are the same, the thermosyphon will shut off. This may or may not correspond to the desired brewing temperature. The dynamics are pretty interesting - to me anyway. One sidenote to this is that the need for a fairly large temperature difference between the group and the water source in order to get the thermosyphon to work means that the thermosyphon group is not the best choice for a double boiler machine where one hopes that the boiler water temperature and group temperature are similar.
-Greg
gscace
Link to "E61 brew temperature (Cannonfodder Device)"by gscace on Fri Aug 19, 2005 11:13 am
lino wrote:That's not your average E61 in that picture. What make is it?
Actually, may not even be a "real" E61 as it apears not to have a expansion chamber. Also, that's the first E61 group I've seen with a flat top and a rough lower casting..
Is it Elektra?
ciao
lino
Astra Gourmet - electric solenoid is on bottom.
gscace
Link to "E61 brew temperature (Cannonfodder Device)"by Strugs on Tue Aug 23, 2005 7:23 pm
I am keeping a log of my experiments on my WWDP web site:
http://strugs.ca/thermal_obsession.htm
I will update it as the project develops.
Sean
Strugs
Link to "E61 brew temperature (Cannonfodder Device)"by barry on Tue Aug 23, 2005 9:22 pm
the thermometer in the foam cup should be angled downward so the tip is at the lower 'corner' opposite where it enters the cup. the business end of the thermometer is the last inch, and when it's angled downward, that portion gets saturated quickly.
btw, someplace i have an analysis of the thermocup technique. i tied a small thermocouple to the thermometer and datalogged the results.
barry
Link to "E61 brew temperature (Cannonfodder Device)"by Strugs on Tue Aug 23, 2005 9:45 pm
Hi Barry,
I started out using the angled thermometer approach, but I found that after about a dozen uses, the excessive heat of the water would make the styro start to degrade, which allowed all of the water to escape through the hole in the lower part of the cup.
I found that using the horizontal thermo worked ok, as I was not looking for an accurate temperature, just a repeatable reference point to shoot for just prior to making the shot.
Sean
Strugs
Link to "E61 brew temperature (Cannonfodder Device)"by cannonfodder on Wed Aug 24, 2005 3:23 pm
As fate would have it, I have one more bolt drilled and ready to go from my original project. If you email me your address I will throw it in the mail and send it to you. You will have to trim it to the appropriate length as I did in the article. Mail may take a few days to get from Ohio to Vancouver.
cannonfodder
Link to "E61 brew temperature (Cannonfodder Device)"by Strugs on Wed Aug 24, 2005 10:33 pm
Cannonfodder - that would be very neighbourly of you.
I will email you my address.
My buddy with the drill press actually attempted to bore out the screw last night, but claims his bit was dull, and could not get through the stainless steel.
Sean
Strugs
Link to "E61 brew temperature (Cannonfodder Device)"by cannonfodder on Wed Aug 24, 2005 10:46 pm
They are hard to drill. You have to have a sharp bit and use cutting oil as you drill otherwise you will burn up your bit. I got my dad (part time wood worker) a bit sharpener a couple of Christmases ago. I just have him sharpen them for me. He is a retired police officer, it gives him something to do.
cannonfodder
Link to "E61 brew temperature (Cannonfodder Device)"by Strugs on Tue Aug 30, 2005 3:14 am
I finally have a shiny stainless bolt with a hole in it today.
I just finished bonding the TC to the bolt using JB Weld and the next 15 hours (curing time for the metal epoxy) will be excruciating.
FYI - I have been updating my "thermal obsession" page here:
Sean
Strugs
Link to "E61 brew temperature (Cannonfodder Device)"by Strugs on Sat Sep 10, 2005 5:29 pm
I found two design flaws in my fre61nkenstein project:
1) the lock washers I used to effectively shorten the length of the bolt did not allow a proper seal between the bolt and the group. I tried different amounts of teflon tape and also tried teflon pipe sealant (basically liquid teflon tape). No matter what I did, the bolt would always leak a few drops during the shot or when running the pump with a blind filter.
2) the part of the TC wire that exits out of the head-end of the bolt is too flimsy. The heat of the bolt coupled with the multiple insertions of the bolt while trying to rectify design flaw #1 resulted in the insulation breaking down and exposing the separate TC wires. The exposed wires made contact at the bolt head, which means that the TC was now measuring the temp of the bolt at the head, rather than the probe at the end of the bolt.
I think that both of these issues are easily resolved (using copper washers instead of stainless would probably allow me to get a proper seal, and the TC could be inserted inside a stainless sheath like what Cannonfodder did with his thermo-probe), but I have decided to take Greg's advice and probe the group further down the water stream.
After I receive the parts, I will update my web page with pics as I (gulp) drill a hole in the group.
Sean
Strugs
www.vanelis.com: top-notch espresso equipment and customer support
Link to "E61 brew temperature (Cannonfodder Device)"by cannonfodder on Sat Sep 10, 2005 8:53 pm
Careful with that one friend. Drill bits like to slide on hard shiny chrome. I would suggest you use a center punch to dimple where you want the center of the hole to be. That will create a well for the drill bit tip to sit in. It will even skate if you use a drill press.
I am surprised that you cannot get a seal using Teflon tape. The top of my bolt is a solid ¼ inch above the bolthole. There is no seal between the GH and bolt on my machine. The tape provides the seal.
Did you ever get the bolt I sent up? It is longer than the one you originally used.
cannonfodder
Link to "E61 brew temperature (Cannonfodder Device)"by Strugs on Sat Sep 10, 2005 9:22 pm
Thanks for the drilling tips. I will definitely take my time doing this - although the WEGA group is behind sheet a metal case, I still don't want to mangle it too badly.
I also found it strange that I could not get a good seal. It is possible that I stripped the threads on the group when I was torquing the bolt into place. It looks ok, and the bolt (and the oem bolt that I have put back in place while I wait for the next mod) both slide in with no problems.
Still have not received that bolt you sent me in the mail. It probably got stopped at the border to ensure it was not some sort of terrorist device... :roll:
Sean
Strugs
Link to "E61 brew temperature (Cannonfodder Device)"by cannonfodder on Sun Sep 11, 2005 11:47 pm
Who knows, I did send it. It looks to be a bit longer (almost twice) as long as the one in you photos. There is a short shield that will fit the hole I drilled in the bolt as well. I cut my original to short for the project. It is long enough to braze in place and insert a TC wire into it, but to short to put a display on the end of.
cannonfodder
Link to "E61 brew temperature (Cannonfodder Device)"by arossphoto on Tue Jul 11, 2006 4:12 pm
cannonfodder wrote:I have two metric omegalock fittings on order, but I do not expect them to fit, but figured I would give it a try. I may even go as far as machining the GH and tap an opening into the chamber like the photos Dan posted.
Sorry to reply to a thread that is almost a year old, but I didn't see any other posts from you regarding those omegaloks you ordered. Based on your later posts about drilling bolts I guess it's probably safe to assume they didn't work out. :wink:
I guess it would also be futile to start looking for something like this myself. Did anyone ever find a ready made solution?
What about purchasing the adapter that Eric S. had made and drilling it out to 1/8" to accept a thermometer?
http://www.home-barista.com/forum...-silvia-t1352.html
I know it's not as accurate as a thermocouple, but I'd like to do something cheaper and prefer the idea of a small digital thermometer attached directly to the group head to act as a guideline.
Thanks,
Andrew
arossphoto
Link to "E61 brew temperature (Cannonfodder Device)"by barry on Tue Jul 11, 2006 5:29 pm
arossphoto wrote:I know it's not as accurate as a thermocouple, but I'd like to do something cheaper and prefer the idea of a small digital thermometer attached directly to the group head to act as a guideline.
the response time on those thermometers is so slow that what you propose really isn't worth the effort. really.
think about it: if it was, wouldn't we all have installed them at some point?
barry
PreviousNext
Return to Espresso Machines
