TimEggers wrote:I've found this in my RK Drum setup too. My roasts became far better when I cranked the heat pre-first crack...(f)irst crack comes right at 10 or 11 minutes at which point I reduce the burners to low (ambient temperature steadily falls to 480F approx. in about 3 minutes) with second crack coming at 13:30 to 15:00 minutes.
Tim,
I too am roasting with an RK Drum, though I've been using a slower ramp to 1st crack (13 min or so). 2nd does tend to come on rather quickly, but I cut the heat just as it starts and pull the beans within 30 sec. most of the time. The roasts are great, but I'm going to try the method you've described and see how it goes.
However, one key detail is the amount of beans going in the drum. I usually roast 2-3lbs. per batch. When I do just a pound, I have to cut way back on the heat to keep it from running too fast. How much are you roasting in an average batch (such as you describe above)?
Cheers,
Paul
