vanboom wrote:In a lot of videos I notice the barista turn the portafilter upside down after tamping to let some loose grounds fall out. When I do this, my dry puck falls out.
I am using the LaMarzocco ridgeless basket and it is very smooth on the inside - but I wonder if something about my tamp is wrong.
Also, after extraction my pucks are nearly identical every time - slightly flaked on the bottom especially around the corners and some of the puck is left in the bottom corners of the portafilter. Could I be tamping too hard?
Hi Don, and welcome to H-B. In contrast to the sage advice given above, I believe something is wrong here. I've been inverting the PF/basket after tamping to remove stray grinds for years, and while I agree that it's not necessary, my pucks never fall out (well, maybe 1 in 1000 does
). Like you, I use a "LM" ridgeless double basket, so that's not an issue.
Tamping too hard should not cause pucks to fall out. Instead (as noted above), it's more likely to be the type of coffee you're using and/or something that breaks the side seal of the puck with the basket (such as a side tap). I'd suggest that you try a freshly roasted commercial espresso blend, pay careful attention to correct grind/dose/distribution, use a simple tamp w/o any kind of tapping, and see if that improves matters.
Further reading: Mark Prince has begun an interesting series of articles on
Tamping Science at CoffeeGeek.
