cafeIKE wrote:Clump breaking, Stockfleth's move, 30# nutating tamps, PF tapping, puck polishing, etc. are pretentions. Espresso survived a very long time without them. Their introduction has done nothing to improve consistency, especially in shops where far too much emphasis is placed on the 'show'. Perhaps paddle-thwacking begat them all?
I have to call full-on bullshit on this.
I'm sorry - but I've
never had a shot in Italy of the quality of the best shots in Scandanavia, Australia and the US. Sure... it's hard to get
undrinkable espresso in Italy (and easy to get that in the US). But great shots? No comparison.
Why?
Because in Italy "drinkable" is good enough.
Espresso is a cultural icon - and a tradition - and you don't change that sort of thing.
Outside of Italy - people are trying to push things forward because they
are not hide-bound traditionalists.
cafeIKE wrote:When a doser is used as designed, a volume of coffee is dropped in the basket, reasonably well centered. A gentle pressure on the coffee spreads it out in the basket. When paddle-thwacked, the coffee is loaded up on one side and needs moving. A heavy tamp on an uneven distribution results in severe density gradients.
Untrue - on both counts.
While you are correct on what happens when the doser is used as designed - there are three things you skip over.
First - as ambient humidity and temp change, the grind must change - which results in the volume dosed changing. As beans age, the grind must change - again, resulting in the dose changing.
Second - accuracy of dose in a commercial environment is vital. With the variables in play, the "doser" model you describe is unlikely to result in accuracy greater than 0.5g. That's not viable unless you're using coffees that are incredibly forgiving (see Italian blends with high counts of CD Brazils and robusta).
Third - a skilled barista can "paddle thwack" dose to a consistent accuracy of 0.1g and with consistent bedding within the portafilter. This is not opinion - it's simple fact.
cafeIKE wrote:When a basket is overdosed coffee expands to the shower screen. Grind must be coarser to allow water to pass due to the extra screen compression on the puck. If distribution is poor and heavily tamped, the water will force its way through the less dense areas of the puck that are not even more heavily compressed by the shower screen, i.e. channel.
Coffee does not expand within the portafilter until the pressure release valve is triggered. In other words...
after the shot is stopped.
The point of updosing certain coffees is actually largely to allow for a coarser grind as this creates a different flavour profile.
Absolutely true that poor distribution will result in uneven extraction. Thus... the importance of the "pretentious" techniques you deride.
cafeIKE wrote:With a proper finely ground dose, the puck may barely touch the shower screen in a small area. As coffee is removed, any resulting pressure is relieved. Only water pressure is controlling the flow through the puck. The puck is more fluid and less likely to channel. This paper on
Coffee Percolation is most interesting. It's a bit heavy on the math, but the concepts are reasonably well explained.
1 - "Proper"?!?! That's dogma. Pure and simple.
2 - And, of course, the paper is also dogma. Interesting - but dependent upon a number of assumptions that are largely (as mentioned above) tradition rather than science.
cafeIKE wrote:Which brings us back to :
Dosers are "by volume" devices.
The issue at hand is how repeatedly a given doser volume matches a dose by weight.
Dose volume and weight rarely track well over time in a volume environment. The combination of the ambient environment variables, additional variables (like grinder temp) and changes to the coffees themselves mean that it's best to choose to dose by one or the other and try to be consistent with that one.
It's the consistency to one of the two that really matters.
Most people who make quality coffee at home seem to try for consistency of weight over time.
Most (good) pros seem to try for consistency of volume over time.
This makes perfect sense. In a commercial environment it's simply unrealistic to try and be consistent by weight. And in a home environment, it's hard to get enough practice in to be able to be consistent by volume.
Both produce good results.
Don't believe anyone who tells you that they do things the right way.
Experiment for yourself. Think for yourself.
If it tastes good to you - it is good.
Dogma stops progression.
There is no golden rule.
