luca wrote:Hey kids,
As you say Ken, these things are all a massive PITA. I have done a bunch of cuppings, blend testings, etc, but I haven't ever tried to make anything statistically significant. In that regard, I have a lot of respect for Jim and yourself.
There is a very small chance that my local LM distributor might be able to help us out on this one. I haven't asked yet, but they usually have a few machines sitting around and a swift and they're usually quite accomodating. The swift doesn't quite get the same sweetness into a shot that you would get from a Robur, but it does get you consistent shots quickly. I figure that if I could borrow a swift and something like an FB80 and a GS3 or whatever they have around, then get a few volunteers, I might be able to organise some sort of a test. Obviously it would be a very narrow test, but at least it would be something.
Thoughts?
Cheers,
Luca
Hi Luca,
I don't want to repeat what I typed in my response to David Lewis, so please read that response in addition to this one.
I welcome your willingness to look at this, which as you state, will not be an enjoyable experience. Before doing anything, however, I think we need to try to avoid the possibility of doing a study that gives an apparent but false result, which could happen if, say, shot curves overlap even though numerical readouts suggest high precision.
As a very first effort I would take a Scace device with a good digital datalogger and plot out, say, 25 shot curves taken at one intended temperature, then do another 25 at a temperature which you think will not produce curves overlapping with the first set. One would have to know to what degree the shot temperature curves are in fact distinct and not overlapping. My guess is that you would have to get the intended shot temp curves close to one degree C apart in order to have separation. If this is true, the hypothesis would not be worth testing because most of us would probably accept that many tasters could detect that degree of temperature difference, and you would just be "proving the obvious."
I have recently posted this set of shot curves from my old vibe Cimbali Junior:
While I did not do 25 shots at each temperature, I was just trying to establish what the degree of imprecision is, not the ability of the equipment to produce very fine temperature distinctions, which it is obvious that it CANNOT. What I can say on the basis of THIS graph is that, as I am using it, the machine can produce shots within about 1 degree F of either side of the temperature I would like to have, e.g. the shots occur within a "band" of about 1 degree C. This degree of precision is not adequate to test the hypothesis that we are discussing, e.g. the ability to produce and detect differences in shots at small incremental temperature differences.
If you can get reliable separation of the curves, without overlap of the temperatures, on the order of (say) 0.5 degree C, then the hypothesis would be worth testing and the results would be interesting.
Good luck!
ken
