by erics on Sat Jun 07, 2008 7:08 pm
The length of the 7/16 hex used to tighten the adaptor into the machine was reduced to accommodate the Vibiemme but the overall length of the adaptor remained unchanged at 1.41". The total length of the probe which extends out of the black plastic body of the thermometer is held pretty close to 2.00 inches. When I say "pretty close", I mean +/- 1/32". With that in mind, the dimension from the bottom of the thermometer to the top of the 7/16" nut should be 0.215" or around 7/32" for all machines other than Vibiemme. Vibiemme should be 0.340" or around 11/32".
As regards your temperatures and pressures, keep in mind that there can be a 1.5 degree differential between what the thermometer indicates and "true" temperature. Thermometers that exceed this number are NOT released for shipment. The same type of comment applies to boiler pressure gages. These are inexpensive 40 mm (1.5") gages and typically have accuracies of between 5 and 10%. Fortunately, changes in gage readings, as compared to singular readings, are pretty good. I will say though that your 1.30 bar and 213.0 F are certainly reasonable.
The idea of flushing until the thermometer reads in the mid 180's and then pulling the shot at 197-198 has received mixed "reviews" mainly because of the sometimes inordinate time between the end of the flush and the initiation of the shot. Your time is EXCESSIVE. Your rebound to ONLY 190 immediately when you stop the flush is WAY LOW. That number should be something like 197.
How old is the thermometer, how old is the machine, and how do you use Anita?
Skol,
Eric S.
