zeromike wrote:so expensive :\
Expensive compared to what? The cost of replacing the pump on your espresso machine?
I ran my plumbed NS Oscar (vibe pump) off an external water bottle for several months without a FloJet. It worked fine, although it ran more quietly once plumbed in (presumably due to the external water line pressure). However, my Rancilio L7 (older one group commercial model, rotary pump) would
not run correctly from a bottle. The problem appeared to be the autofill rather than the pump per se, although rotary pump output pressure does depend on input line pressure.
My 2 cents: reconsider your plumbing options. If you are near a water line, even something as simple as an icemaker kit from a local hardware store will work (although adding a pressure regulator and water filter/softener is a good idea).
Although some have run plumbed machines in carts off bottles w/o FloJets, others who should know (Chris Nachtrieb) have indicated this is not recommended. If you really can't plumb in your machine, consider a FloJet as good cheap (~$100) insurance for an expensive investment. Personally, I'd be more concerned with the additional noise of the external pump than the expense.
