gscace wrote:Has Garanti makes a 1 kg capacity roaster. Mine is electric.
-Greg
Hi Greg,
I thought yours was a 2kg roaster. Oh well. I also think their stuff is more expensive and probably out of the range of what I have been discussing.
Best,
ken
-Greg
alsterlingcafe wrote:After going to their website and looking through the literature, I'll venture that they've got a good track record. And from what you've added Dave, I'll also venture that they're built like a brick house. And for that reason alone, I don't think that machine, or any roaster, will ever find its way into our home!
I'm right back to where I was, in so far as thinking that coffee roasting belongs in the garage or outside. Unless I'm doing something wrong (?) my Hottop has a post-roast odor that I think comes primarily from the filter, and then from the baked on residue on the some of the venting hardware. Even when I've roasted on the balcony of our old townhouse, the smell found its way all the way up to the third floor. In our new digs, and as we have much more room, I roll it up to the side door to the garage. I also open one of the garage doors to allow a flow of air; all that for a Hottop. Even with venting, I really don't understand how a roaster can be put inside an enclosed living space?
DaveC wrote:However, if you want to roast inside, you are limieted to the Hottop or the Gene Cafe (The Gene with the larger chaff collector that takes a 100mm vent hose attachment). Even so, I personally don't use a roaster in my house and never would....my god, imagine if the beans caught fire!
DaveC wrote:I must confess to also being puzzled about this obsession with getting "commercial roasters"...unless you are in business, or have some other reason for doing so, it's really not worth it. I only use my Toper now if I have a need for a lot of coffee quickly. For my personal and family use, I always use my Gene Cafe. The Gene is an easy roaster to use, but a hardish roaster to use well. Once you learn how though, the results (and the production rate) can usually exceed anything that can be produced in a basic Hottop and even my Toper. It is unfortunate that the manufacturers advice on roasting on the Gene, leaves much to be desired!
Ken Fox wrote:So what are the practical things I take issue with? For one thing, the price is simply way above what most dedicated home roasters would pay; around $5000 plus crating and shipping if you want such "optional" things as a cooling tray.
ken
Espressyned wrote:Is the price of this roaster really 5K? and is the cooling tray really an option?
The price on the sales brochure you linked to starts at $3,800.00...
Ken Fox wrote:......Aaron confirmed my suspicions about two issues with this roaster; for one thing, it does NOT cool the beans well in the cooling tray if you roast anywhere near stated capacity. This will depend on what you consider to be an adequate rate of cooling, but this roaster cools 4oz of beans no faster than my roaster cools a pound (2 minutes). Secondly, chaff removal is not very good and the beans get dumped with residual chaff. My roaster has this problem as well, probably worse than the Diedrich Home Roaster, and it is an annoyance. ken
Teme wrote:Pinhalense has a couple of sample rosters in a design similar to the Jabez Burs / Probat. As far as I know, these cost around $1000 ex factory. I have emailed them for details: http://www.pinhalense.com.br/equip-i-tc0.htm#caract (and there's another model pictured below):
Rainman wrote:Teme- is that for the fancy brass model? Did you find out anything about temp management- not just turning up the heat on the burner, but adjusting air flow and measuring temp? I'm assumming at that price, you're probably on your own for at least most if not all of that.
Ken (I'm hoping he's still watching this thread)- this looks similar to your setup; where did you end up getting your gas jet and thermocouples from?
Ray
Ken Fox wrote:Ray,
The gas burner came from Charles A. Hones Co., a smallish manufacturer of furnaces and related items. They are/were located in New York, and used to have the somewhat amusing web address of http://www.cahones.com
Presumably someone pointed out to them how that URL might be otherwise interpreted, and they either have a new web address or have simply eliminated the website (I've had no contact with that company since buying the burner). This burner was located for me by Barry Jarrett, who found the same burner on an authentic Probat/Burns type roaster, a roaster that presumably was a model for my roaster, which is a knockoff.
The Thermocouple came from Omega; they will make virtually anything for you, to your specifications, if you are willing to design it yourself and to wait a couple of weeks for fabrication.
The most difficult part was bending the probe so as to get it into the middle of the rotating bean mass, while avoiding having it get chewed up by the roaster drum's stirring vanes.
ken
Rainman wrote:How did you go about designing a thermocouple? I'd think whichever one you got would probably work for this machine.
Ray
Rainman wrote:is that for the fancy brass model?
Rainman wrote:Did you find out anything about temp management- not just turning up the heat on the burner, but adjusting air flow and measuring temp? I'm assumming at that price, you're probably on your own for at least most if not all of that.
Ken Fox wrote:...here is a picture of the Cahones burner:
ken
Rainman wrote:Hmm.. not quite what I thought. For some reason, I envisioned something elongated w/ maybe 6-8 holes running along the bottom of the drum. This looks like it is mounted vertically on the back of the drum and may have a fan behind it. Ken, please forgive the 20 questions, but if that's how it works, does chaffe blow out toward you through the front of the roaster- or is there no fan, and you roast mostly by radiant heat?
Ray
Ken Fox wrote:I'm not completely understanding your questions. The drum itself is perforated but only on the back. The flame from the burner contacts the bottom (unperforated) part of the drum as it rotates. There is a fan which mostly serves to cool the coffee in the cooling tray after roasted beans are dumped there, but there is an (uncontrollable) flow of air through the roaster that the fan has an impact upon. About 10 or 20% of the chaff does (mysteriously) end up in a chaff tray below the drum, but I"m not sure how it gets there. The majority of the chaff is mixed in with the coffee at the end of the roast. I get rid of the chaff by dumping the roasted coffee into a wire mesh basket and putting that over a strong fan that is on the floor. It blows the chaff up and out. I am now wearing safety glasses when I do this as the swirling chaff has gotten into my eyes a few times, and once or twice caused small and annoying corneal abrasions.
ken
