www.eccocaffe.com: custom coffee roasted in Northern Italian style
Did I damage my grinder (foam got stuck)?
Link to "Did I damage my grinder (foam got stuck)?"by mmm on Sun Jun 01, 2008 12:00 pm
I feel really stupid for doing this, but today I was trying to clean out some of the grounds in the doser (Macap M4) with a foam brush. After that, I stuck it lightly up the chute to try and remove some of the remains there. During this time, I also turned the grinder on in case there were any remains left, and I guess I stuck the brush up a little too far because a corner of the brush got sliced off. Running the grinder a couple of times removed the two pieces that got sliced off (pictured below), but do you think I did any damage to the grinder or burrs? I'm kind of scared since it is only a couple of days old. I ground some beans afterwards and they seemed to come out fine with no issues.
mmm
Link to "Did I damage my grinder (foam got stuck)?"by djmonkeyhater on Sun Jun 01, 2008 12:07 pm
I can't imagine. That foam has so little structure I can't see it doing much.
Your portafilter basket should catch any remaining particles so maybe grind a sacrificial shot and forget about it.
wes
djmonkeyhater
Link to "Did I damage my grinder (foam got stuck)?"by HB on Sun Jun 01, 2008 1:03 pm
mmm wrote:Running the grinder a couple of times removed the two pieces that got sliced off (pictured below), but do you think I did any damage to the grinder or burrs?
I agree with Wes. The foam was caught by the sweeper vanes in the grind chamber, not the burrs themselves. It would take something a lot harder than a few bits of foam to damage them.
Link to "Did I damage my grinder (foam got stuck)?"by TimEggers on Sun Jun 01, 2008 1:41 pm
My Mazzer will chop wood (but I don't recommend it). Relax your grinder is fine.
Tim
LMWDP #202
TimEggers
Link to "Did I damage my grinder (foam got stuck)?"by sweaner on Sun Jun 01, 2008 1:51 pm
I'm glad it wasn't your finger! :roll:
Scott
sweaner
Link to "Did I damage my grinder (foam got stuck)?"by Randy G. on Sun Jun 01, 2008 3:08 pm
TimEggers wrote:My Mazzer will chop wood (but I don't recommend it). Relax your grinder is fine.
I think the Kony's burrs are rated at two cords before needing changing... :shock:
There is no way that the foam could damage the burrs unless it is left in there and it melts from friction, and I also agree that the ejection fingers are what caught the foam.
In any case, if there is ever any suspicion that foreign matter got into the grinding chamber, the best course of action is to turn off the grinder, unplug it and remove the top burr carrier and examine the burrs and grinding chamber.
"Wow! Look how foamy the crema is!"
Espresso! My Espresso!
Randy G.
Link to "Did I damage my grinder (foam got stuck)?"by cannonfodder on Sun Jun 01, 2008 11:32 pm
The Kony is only rated for twigs, you have to the 3 phase Robur to grind logs.
Coffee, for all intent purposes, is wood. You could probably feed the entire brush, handle and all, to the grinder and not make any dents in the burrs. Although I would not try it. Don't sweat it, your burrs are good for another hundred pounds of coffee.
cannonfodder
Return to Espresso Grinders
