Descaling Rancilio Silvia - when and how
Link to "Descaling Rancilio Silvia - when and how"by gabriel on Mon Oct 29, 2007 5:38 am
How often do you need to descale an espresso machine ?
The machine is on about 2 hours in the mornings, making 2-3 espressos a day with no steaming
Using only mineral water
Also how should I do this - I got few packs of cleancaf with the machine which say I need to add warm water mix and pass it once.
Is it that simple ?
Does the machine needs to warm or cold when doing this (i.e. do I need to wait for the boiler to get to boiling temp or can I use room temp. water ?)
thx
/gabi
gabriel
Link to "Descaling Rancilio Silvia - when and how"by HB on Mon Oct 29, 2007 7:54 am
This video shows how and Descaling dedicated brew boiler espresso machines elaborates on the steps and frequency. The boiler needs to be hot for the descaler to work well. Remember not to run the pump continuously for more than 1 minute; most vibe pumps need 1 minute rest for every 1 minute of operation to avoid overheating.
Link to "Descaling Rancilio Silvia - when and how"by gabriel on Mon Oct 29, 2007 9:26 am
Thanks Dan, looks easy
Any idea of how often should I be running this routine ?
I have seen people saying to do this once a month while others say once every 6-12 month
I guess that depends on the usage profile, but are there any rules of thumb ?
/gabi
gabriel
Link to "Descaling Rancilio Silvia - when and how"by HB on Mon Oct 29, 2007 12:07 pm
gabriel wrote:Any idea of how often should I be running this routine ?
The frequency depends on your water hardness and usage. Jim's FAQ covers how to calculate it; I've excerpted my summary post from the other thread for your reference. If you don't know the water hardness or don't want to think about it, descaling every month or two can't hurt. The cost of a lifetime supply of citric acid (descaler) is less than a pound of coffee.
While we're on the topic of cleanliness, don't forget to backflush Silvia too. The CleanCaf has a mild detergent that does some of the work, but backflushing is much more effective and less expensive over the long haul.
HB wrote:There's also Section 4, Water Treatment and Preventive Descaling for Espresso Machines in Jim's Insanely Long Water FAQ. Below is the relevant excerpt:
Descaling Solution - Generally, a flush through descaler uses about .5 to .75 fluid ounces (1 to 1.5 tablespoons, or 8 to 12 grams) of citric or tartaric (grape) acid powder dissolved in 1 liter of water. This is a 2.25% to 3.5% solution, equivalent to 33% to 50% dilute lemon juice. Cleancaf and other coffee manufacturers' descalers use this formula. Theoretically, these amounts will dissolve about 12 to 18 grams of scale per liter, but that would require leaving the solution in for several days; in practice, it is used for an hour or two to dissolve up to 5 grams of scale.
The formula is mild enough to be harmless to espresso machine components, but it will come out of brass or copper machines with a slight greenish tinge. This comes from milligram levels of dissolved copper and is no cause for alarm.
Five pound bags of citric or tartaric acid cost about $10 at home brewers' or soapmakers' supply stores. This is roughly a 20 year supply.
Descaling Intervals - Know the hardness of the water you're using, and how much you use the machine. Descale when accumulations are between 2.5 and 5 grams. More often is a waste of time, less often may result in scale build up. Check out section 1.7 for instructions on determining your set up's scaling rate.
Single Boiler Machines
For single boiler machines, preventive descaling is no problem, just follow the instructions given by the manufacturer. In general, this involves filling the boiler, letting the solution work for about ten minutes, and replacing it by running it out of the steam wand under pump pressure. This procedure is repeated three to five times, until about a liter of descaler is used up. Then the machine is flushed with water until any taste is gone.
Or if you prefer, my own...
Descaling espresso machines in a nutshell:
Preventative descaling of a single boiler (Rancilio Silvia et al) is trivial - fill the boiler with descaler (or CleanCaf), let it sit a spell, flush the boiler a few times with fresh water. Descaling an HX - not the steam boiler - is even easier. Fill the HX with descaler (citric acid), let it sit a spell, flush a few times with fresh water. Since the HX has less volume then the boiler, it fills and flushes in a jiffy.
Preventative descaling of the steam boiler is a pain because not all machines include a drain tap (e.g., like the Cimbali Junior), forcing you to use the water tap as the drain. The manufacturer does this to save costs. BTW, it's not absolutely necessary to force overfilling by disconnecting the auto-refill. You could also tilt the machine slightly and the autofill should kick in long enough to cover the scale line.
Choosing not to do preventative descaling is unwise. Ask any vendor what is the most common cause of espresso machine failure, commercial or otherwise - they'll all say "scale". If you want to keep your HX espresso machine running well and not spend a lot of time on maintenance, at least run descaler through the HX. It shouldn't take more than 5 minutes once a month.
Link to "Descaling Rancilio Silvia - when and how"by boxofish on Sun Mar 23, 2008 3:02 pm
i've got a bit of a noob question i hope someone won't mind answering hopefully. as the proud owner of a r. silvia i would like to know if i can use citric acid to back flush as well descale my machine. or is there something else i should use to back flush?
thanks,
darryl
boxofish
Link to "Descaling Rancilio Silvia - when and how"by HB on Sun Mar 23, 2008 3:30 pm
boxofish wrote:or is there something else i should use to back flush?
Cafiza, JoeGlo, and Puly Caff are a few formulations specifically for backflushing. Their job is to remove baked on oils; citric acid is not well suited for removing oils since it's not a detergent. See Backflushing Rancilio Silvia...please explain what it is for more details.
Link to "Descaling Rancilio Silvia - when and how"by boxofish on Wed Mar 26, 2008 8:02 pm
perfect, thanks for the reply...that makes good sense.
boxofish
Link to "Descaling Rancilio Silvia - when and how"by Endo on Thu Jul 24, 2008 9:26 pm
HB wrote:The boiler needs to be hot for the descaler to work well.
Is this right? Descaling when it's hot? My Saeco liquid descaler says a max of 60C. Also, I've seen many sites that say to do it only cold (like this one for example):
http://coffeemachine.com.au/descaling-your-coffee-machine-a-6.html
Hot or cold? Which is right?
Endo
Link to "Descaling Rancilio Silvia - when and how"by cannonfodder on Fri Jul 25, 2008 11:11 am
I guess that would be dependent on your cleaner. If it states 60C then I would stick to that. Most descalers are little more than an acid solution. It is more aggressive when hot, so a cold boiler may need several days for the solution to work its magic where as a hot boiler may only take a couple of hours. I always run hot.
cannonfodder
Return to Espresso Machines
