The good news is I just enjoyed an extremely good shot of Vivace Vita. Equal to or better than any I have made before. I think I'm going to like this machine.
So far I have noticed:
1. The grind is MUCH fluffier by weight than grinds from the Le'Lit PL53. (I don't single dose the PL53, so can't say for sure it wouldn't be similar if single dosed.)
2. The grind compresses down to the same volume as the equivalent weight grind from the PL53.
3. In order to get the required post-tamp volume into a basket, the pre-tamp volume overflows the top of the basket. When I remove the basket from the PF holder, some grind spills over the edge.
I have an idea of a way to overcome this. Place the basket, with yogurt cup funnel, on the base of the grinder and grind directly into it. Tap on counter to settle grinds, remove yogurt cup, distribute, then tamp. If this works out I might just remove the PF holder altogether...
I should point out that I am using a triple basket and playing around with doses (post grind) between 19.2g and 20.2g.
-dg-
