RegulatorJohnson wrote:i think a descale is in order but im a bit afraid of it cuz chris said i shouldnt. i have descaled my pulser before but this one is a rotary pump that is plumbed in.
And, for sure, in the case of the Vetrano, he is absolutely correct. The size of the pump's suction hose (tubing) on the Vetrano is 5x3 mm. That's 5 mm OD and 3 mm ID. If you try to "suck" descaling solution from some static tank/reservoir through that tubing, you will wreck the pump.
I thought I had a solution - see attached pic of descaling kit - but APPARENTLY my little pump is not strong enough to overcome the check valve that is screwed into the entrance to the hx.
It's back to the drawing board as the intent is, of course, to make this kit as simple (and as totally complete)as possible for the typical user.
