i guess i actually pulled out the gicleur screen/the smaller bolt and not the actual mushroom. the screen was very clean. no scale to be seen anywhere. i suppose i should get the larger wrench and check the actual shroom.
i did have a thought on a possible de-scale solution for a rotary. so i already have the blue thing that holds the filters. what if i removed the dead softener and filled the blue thing with de-scale citric acid solution. then screw the blue filter holder back into its holder. then restore the line pressure except now there is de-scale in the line inside where the softener cartridge goes. then i can refill the boiler and the HX with the descale from the filter holder. eventually all the descaler will be passed through and i can put in the new softener cartridge and rinse the system with the soft water. seems like it would work if i rinsed carefully, etc. i have a cut off in front of the filter housings so it would be simple as switching the filter. which im going to do anyway.
so this would solve the line pressure issue of ruining the rotary pump, yes? so then are there other concerns with descaling?
thanks for your time.
jon
