For access to the article content, click below:
Read more...
ken
Rainman wrote:Wow! nicely done, Ken- if I didn't know any better, I'd swear you've had experience doing drug studies in the past. Good transparent methodology, BUT- it's just one study, and it would be great if someone else could repeat it and find the same results. One silly question- can you post your roast curve? I'm wondering what sort of temp ramp you did (especially up to and through 1st crack- looks like it was pretty quick, but you still got a nice FC+ roast?
Nice "myth-busting" btw!
Ray
I actually have a research background in my distant past, having published articles in (the now supplanted) American Journal of Physiology, as a college student, and in the Journal of Clinical Oncology and International Journal of Radiation Oncology, Biology, and Physics when I was in post graduate training and in practice as a physician. Jim Schulman, who came up with the experimental design and who did the data analysis, has recently obtained a ph.D in Sociology at the University of Chicago. So both of us have experience in experimental design and statistics.
I have cobbled together an idealized roast curve ...
I am calling it idealized because although I roast with the aid of a rigid thermocouple mounted in the drum of my roaster, along with a fluke datalogger, I haven't datalogged any roasts in 6 or more months. The only change I've made in my roast technique since the previous datalogged roasts is that I let the drum cool down slightly more before introducing the beans, although it was always under a real temperature of 380F.
EDIT: I made a data transcription error in constructing the first graph I put in this post, which I have just corrected. If you saw this post in the last hour, I apologize for any confusion I may have caused you
Finally, it is really hard if not impossible to extrapolate roast profiles from one roaster to another, and what works well on my drum might work very poorly in another roaster; you just have to experiment to find what works best in any particular roasting setup.
ken
Rainman wrote:[ Thank you for putting this up; I was just curious about your roasting setup, and didn't see too many details mentioned in the article (other than the photo). Which sample roaster is that?
Ray
Matthew Brinski wrote:Phenominal.
I am actually surprised at your finding that coffee which has been frozen does not deteriorate faster (after defrost) than if it were not frozen initially. I have always had a perceived impression that it does in my use. I don't frequently roast at home though, so the coffee that I experiment with freezing is usually frozen anywhere 2 to 4 days out from roast when it arrives via shipping, as opposed to you freezing within an hour of roast completion. I wonder if that's a considerable variable? Probably not.
Thanks for posting the project. Awesome effort, seriously.
jrtatl wrote:Thanks for the great article Ken.
As a side note to anyone interested in anecdotal evidence, I almost always freeze my coffee -- with great results.
I buy in bulk to save $$. As soon as the beans arrive in the mail, I use a Foodsaver to vacuum seal 8 - 10 oz of beans in several bags. I then put the vacuum bags in my freezer. I typically use the coffee within 2 months, and it works pretty much as good as the fresh stuff.
jrtatl wrote:As a side note to anyone interested in anecdotal evidence, I almost always freeze my coffee -- with great results.
jesawdy wrote:In the more anecdotal evidence column, I too regularly freeze fresh roasted coffee, but have never held anything longer than two months yet. Seems as good as fresh to me.
I typically order 10 lbs of coffee per month (not all for my lone consumption - home, work, friends) from a local roaster. I order 5 lbs around the 1st and another 5 lbs around the 15th. I have been letting the coffee rest a few days before I freeze it, so I am typically freezing it after 3 days rest. The coffee is in individual 1lb bags with one-way valves. I simply tape over the valve, and toss it in the freezer. When I need coffee, I pull the bag out, let it come to room temp, pull the tape off the valve, and start using it right away. Obviously, as often as I am ordering, most coffees are only frozen for 2-3 weeks at most. (I should add that my freezing procedure was inspired by Ken's comments on freezing here some time ago.)
I did stock up on some other roaster's coffees during the HB Holiday promotions. I kept a few pounds of that around as long as two months, and they seemed fine to me. I did make a conscious effort to NOT discuss my experience with these "older" coffees, as I didn't want to consider it exactly identical to fresh, giving the benefit of the doubt to fresh and never frozen coffees.
luca wrote:So how are people doing this ...
Ken, it looks to me like you freeze immediately after roasting, defrost, then allow a few days to degas. Others seem to allow a few days to degas, freeze, then defrost and use. Is that right?
Cheers,
Luca
Cheers,
Luca
Cheers,
Luca
Dogshot wrote:Great stuff Ken. I can't believe the quality of the work that you and Jim, among others, are able to do on a consistent basis.
These are my thoughts as well. It is a very interesting and enjoyable read, and the question it seems to address is "is using coffee that is frozen 1-2 hours after roasting as good as using fresh coffee that is never frozen?". My suspicion is that very, very few people are in a position to benefit from roasting their coffee (or buying 1-hour old coffee) and freezing it immediately. While this study might convince home roasters to look into 1kg+ roasting units, or at least spring for the 5lb BBQ drum, it does not seem to directly address the question "is using coffee that is frozen 4-5days after roasting as good as using fresh 4-5 day coffee that is never frozen?". My guess is that the vast majority of us are probably more in this situation. Any interest in doing the study again with 4-5 day old coffee?
Mark
