SamuraiE wrote:OK, so what do you think? Temp seems to be within the guidelines albeit on the lower side. This machine from day one really seems to need a fairly long flush (5 oz) just to get the water calm and smooth out the dance.
Yes, I think we can safely eliminate mechanical issues. It looks like you are overflushing the group. I made the same error during the early days of the review due to my experience with prosumer E61s; the Cimbali Junior still needs to be flushed, but not nearly the same volume or frequency as a prosumer E61. For those unfamiliar with Junior's group, below is a nice diagram from the owner's manual:
Cimbali Junior hydraulics diagram
The heat exchanger is the cigar-shaped tube resting in the boiler water. The thin tubing inside it is the injector coming from the pump. This "dead end" heat exchanger is different than your typical prosumer E61, which is usually nothing more than a section of copper tubing passing from one end of the boiler to another:
E61 group hydraulics diagram
The grouphead is heated by the thermosyphon bringing heat from the boiler (red / blue arrows). Junior's grouphead is directly attached to the boiler by a heavy "trunk" and picks up its heat by conduction. The water in the heat exchanger also circulates heat to it (hotter water rises, cooler water falls). There are practical consequences of these two designs for the barista. The one that's most likely in play for your situation is Junior's "group memory." Because of the heavy trunk, large insulated boiler and heat exchanger, and beefy grouphead, Junior's temperatures are phenomenally stable under a hard load, which is what the machine was designed for. Junior's temperature management is tricky if it is being used intermittently, and worse yet, if you inadvertently overflush a few times, he'll remember. Other machines I've used don't have as a long a thermal memory -- three minutes and most forgive all mistakes. Not Junior.
In the article I described how I programmed the dosing keys to make flushing easier (Big Flush = 120ml, Double = 90ml, Mini Flush = 60ml, Spritz = 30ml). I only used Big Flush once in the morning and the rest are Mini Flushes. Your temperature trials were all preceded by Big Flush+ and likely accumulated some downward thermal memory. As I mentioned earlier, I got caught by the same error and it was Ken Fox and Jim Schulman who pointed me in the right direction, which begins by forgetting what you know or have read about using prosumer E61s -- applying the same regime to Junior will result in consistently sour shots.
