www.cafemakers.com: good coffee brings good business
Checking an E61 Espresso Machine for Scale
Link to "Checking an E61 Espresso Machine for Scale"by erics on Thu Apr 10, 2008 8:58 pm
The easiest way to check an E-61 machine for scale build-up is to remove the gicleur chamber nut and mushroom and do a visual inspection of both the removed parts and the internals of the grouphead which are now before your eyes.
Tools Needed: (a) 7/8" or 22 mm or 8" Crescent wrench for the gicleur chamber nut; (b) 1-7/16" or 36 mm or 12" Crescent wrench for the mushroom nut; (c) needle nose pliers; (d) electrical tape for wrench openings. Note that some 12" Crescent wrenches may not have a large enough jaw opening to fit the mushroom nut - measure before you buy.
If you are working with a Vibiemme machine, you do not need the larger wrench for the mushroom nut but will need a 5 mm allen head wrench to remove the hex bolts which hold the mushroom in place. Apply some electrical tape or the equivalent to the wrench openings.
Start by having the machine off, unplugged, and, preferably, at room temperature. Apply a "counter-hold" to the mushroom nut using the 36 mm wrench and remove the gicleur chamber nut with your 22 mm wrench. The stainless steel gicleur filter screen may or may not come off with the nut. It doesn't matter - use the needle nose pliers or your thin fingers if it stays with the grouphead.
End of Part I - stay tuned for Part II.
Skol,
Eric S.
erics
Link to "Checking an E61 Espresso Machine for Scale"by erics on Thu Apr 10, 2008 9:17 pm
Now remove the "mushroom" using a 36 mm wrench.
The scale buildup on the mushroom AND the walls of the mushroom chamber are good indicators of scale buildup on the internal surfaces of the hx.
The mushroom chamber walls have an area of about 10.5 square inches and, along with the hx surfaces, can effect the rate at which the machine recovers after making an espresso drink. I have soaked my entire mushroom in simple white vinegar many times and hence the scale buildup for this particular photo shoot is zilch but you can easily see what it looks like when it is clean.
End of Part II - Stay tuned for Part III
Skol,
Eric S.
erics
Link to "Checking an E61 Espresso Machine for Scale"by erics on Thu Apr 10, 2008 10:21 pm
After you remove the mushroom assembly, remove the brew valve spring and brew valve using needle nose pliers. Soak all of these parts in descaling solution or white vinegar for about thirty minutes and then rinse all parts under running water, cleaning the mushroom with a green "scrubby".
I poured some white vinegar or descaling solution into the chamber with a blind basket in place and the brew lever in the brew position (this ensures that the drain valve is closed). I let this soak for about 30 minutes and used a toothbrush on the mushroom chamber walls. The result is as shown after draining the solution.
Re-Assembly:
Ensure that the mushroom assembly is rinsed well and that all of the small holes are clear by holding the mushroom up to a light source. There are four holes which feed the gicleur chamber and then, of course, the 0.70 mm gicleur (typical) itself.
With the brew lever in the exhaust position (all the way down), plop the brew valve in place and place the spring over the brew valve. Now screw the mushroom into place hand tight. Tighten with the 36 mm wrench - just snug - maybe 1/12 of a turn maximum.
Place the gicleur screen over the gicleur itself and screw the gicleur chamber nut in place hand-tight. Tighten with the 22 mm wrench - just snug - maybe a little over 1/12 turn.
Flush the machine well - maybe for about 5 minutes - remembering to not run the pump for over 30 seconds or so before giving it a rest for a similar period of time.
This is not meant to be a descaling procedure but the methods proposed will certainly remove a goodly portion of scale (if present) from the areas mentioned. Once you do this (and I can understand the trepidation), you will wonder why it took so many words to describe a simple procedure.
Skol,
Eric S.
erics
Link to "Checking an E61 Espresso Machine for Scale"by cannonfodder on Sat Apr 12, 2008 12:55 am
Nice post. Let me add one thing that experience has taught me. If you have a plumbed in machine, turn off the water. Otherwise you will need to mop your floor when you remove the group bolt.
cannonfodder
Link to "Checking an E61 Espresso Machine for Scale"by edwa on Sun Jun 08, 2008 9:46 pm
Thank you for such a wonderful instruction, it made the process a lot less intimidating. It was nice to see that after almost 2 years of using softened water the scale was almost nonexistent. The hardest part of the whole procedure was getting the mushroom threaded back in against the pressure of the spring and then worrying if I wasn't damaging the threads.
edwa
Return to Espresso Machines
