Thanks Greg... If wood doesn't work out for the knobs and lever I will take you up on that idea...
The knob for the steam tap is pretty nice...Ya... but did you note that there was no steam tap retaining nut on the end of the stam tap... Niether did I!
It turns out that the tap that I got is missing the retaining nut for the tap shaft. I don't know how I missed that when I tore it apart but after I turned the knob for it I realized that I had not allowed for the retaining nut. Then I realized I had never taken the nut off in the first place. Anyway last night after work I redesigned the tap knob by cutting the knob stem down and then taking a peice of 1" stainless and doing a press fit over the stem with an arbor press and some JB Weld. I did have a chance to polish up the rim and stem of the knob before fitting the new stainless stem.
Now that I have spoken to our resident expert on handle and knob coverings (Thanks Richard) I will attempt to turn my own. Also since I have an issue now with the new setup because I have the tap end of the knob traveling over the steam tap body... I grooved in an o-ring that makes contact with the body and keeps the stainless from touching. It also gives a really nice glide to the turn and offers two points of support for the knob. the blue color is release agent...
The valve stem is sticking out because instead of cutting a square at the bottom of the knob I opted for a round hole. I painted the stem with release agent so the JB won't adhere to the tap but will form the square very accurately. So now it sits over night and I will see tomorrow morning if I can get things apart somewhat easily. I am not worried if the stem comes out hard because it is a bit out of alignment anyway and it would take some work to get it back to true.
Also the inner o-ring has been removed but you can see the groove for it. It forms such a great seal between the knob stem and the valve body that I am going to have to drill a 3/32 hole above the o-ring in oreder keep air pressure equalized when the tap heats up...
Still having a blast.
Bob C.
(Now officially a lever purist!)
LMWDP #012
