pauljolly65 wrote:The VBM has me on the steep learning curve again.
After years with a Solis SL-90, a machine of similar class to a Silvia, the Vibiemme is a doddle.
Two things to check:
Boiler should range from 0.9 to 1.1max. Adjust down if higher. If you don't steam a lot, 0.8 to 1.0 is ideal.
Brew pressure should hold steady. If the brew pressure varies more than ±1/2bar with the heater, it is likely the OPV has the wrong spring.
good coffee, 16g in 14g basket, side to side shake to distribute, light level tamp. Flush until steam stops, plus a second or two. Load and pull. Adjust grind to give 60ml in 30s. No need to flush again when pulling another shot within a few minutes.
Thursday, using the above, a fellow with his new Vibiemme pulled shot after shot of espresso porn.
Unremarkedly, tasty.
